Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2017
    Apr 2017
    1
    Default Extrude or Pushpull on angle
    Hi, I'm new to 3D modeling and have a possible simple question to do with Extrude or Pushpull. I'm trying to make a indentation on a box that will go in on a 45 degree angle. I have attached a sketch (PDF) to show what I'm trying to achieve. Any tips or help would be greatly appreciated. Extrude angle.pdf
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor cdean84.
    One of the commandline options for the Extrude command is Path.
    You will need to create your path before starting the command.
    It is extremely important, to follow the commandline prompts, as by so doing, you will learn of numerous command specific options available, some of which may be non-intuitive.
    Whoops, I just looked at your pdf, and the Path option is not going to help you on this one.
    Personally, I would create the void as a 3D Solid entity, outside of the cube.
    Then you can move or copy it into the desired position of the void, or in this case voids.
    Then you can use the SUBTRACT command to create the voids.
    Read and follow the commandline prompts.
    Your first selection will be of the entity from which subsequent selections will be Subtracted.
    There are lots of different ways to do this, but this is probably the easiest to explain.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    This is simple enough using subobject selection. First draw the rectangles on the surface of the box, then using PressPull (PP) to remove to the depth required. Then hold CTRL down, pick the edge that needs to go away, pick the grip that appears, move your cursor and snap perpendicular to the opposite side. Repeat for the other one.
    Screencast can be found here
    http://autode.sk/2o5nSCk
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by rkent View Post
    +1 Nicely done rkent!
  1. How do I extrude on an angle?
    By laurenl in forum Autodesk Inventor
    Last Post: 4th Feb 2016, 01:20 pm
  2. How to extrude at an angle
    By mutski in forum SolidWorks
    Last Post: 25th Apr 2014, 02:18 pm
  3. Extrude At angle ?
    By fpanjsh4 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Dec 2011, 03:11 am
  4. Replies: 16
    Last Post: 4th Aug 2010, 02:42 pm
  5. How to Extrude with Angle?
    By mechanical engineer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Dec 2009, 10:59 am
