cat3appr Posted April 12, 2017 Share Posted April 12, 2017 Hello, I used to apply this procedure and it always worked, till now... i guess i'm missing something. Please see the screenshot, and this is the entire DWG https://drive.google.com/open?id=0B12JygCn5zCmU0ZNWWJ6TXhsa0E I need to rotate the panel in model space to match the viewport in paper space, as per photo. I've been doing this by applying the procedure: UCS / N / 3 / and then pick up the 3 corners.. I do this but is not working. Please let me know, I need to apply this method, no other commands. cheers! I Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 12, 2017 Share Posted April 12, 2017 Try setting UCSFOLLOW=1 Quote Link to comment Share on other sites More sharing options...
rkent Posted April 12, 2017 Share Posted April 12, 2017 Follow up the UCS sequence with, Plan, Current. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 13, 2017 Share Posted April 13, 2017 Like Rkent we also do UCS OB S "giveit a name" go to layout UCS R "giveit a name" PLAN then scale. Only word of caution is OBJECT needs to have generally zero z's else UCS will be a tilted plane. You drawing looks like a civil plan so using 3 points may be that you will end up with a Tilted plane rather than a view at 90 in the Z direction. Quote Link to comment Share on other sites More sharing options...
