Results 1 to 2 of 2
    Senior Member
    Manufacture
    BrianTFC's Discipline Details
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    188
    AutoCAD Send attchement as PDF in an Email
    All,
    I found the really cool lisp routine to send an AutoCAD drawing as an attachment in an Email and was wondering if it could be modified to send a PDF instead.
    Code:
    (defun c:eMail (/ _catch file outlook email)
      ;; Using Outlook, eMail selected object(s) in a temporary DWG file
      ;; Many thanks to Ron Perez (ronjonp) for the Outlook example (http://www.theswamp.org/index.php?to...4794#msg324794)
      ;; Alan J. Thompson, 03.28.11
      (vl-load-com)
      (defun _catch (f a) (not (vl-catch-all-error-p (vl-catch-all-apply f a))))
      (if
        (and
          (or (ssget "_I") (prompt "\nSelect object(s) to eMail: ") (ssget))
          (setq file (vl-filename-mktemp "" nil ".dwg"))
          (_catch 'vla-WBlock
                  (list (cond (*AcadDoc*)
                              ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
                        file
                        (vla-get-activeselectionset *AcadDoc*)
          (setq outlook (vlax-get-or-create-object "Outlook.Application"))
          (setq email (vlax-invoke-method outlook 'CreateItem 0))
          (_catch 'vlax-put (list email 'Subject (strcat "Emailing: " (vl-filename-base file) ".dwg")))
          (_catch 'vlax-invoke (list (vlax-get email 'Attachments) 'Add file))
         (progn (princ "\nOutlook active...")
                (vlax-invoke email 'Display :vlax-true)
                (vl-file-delete file)
      (foreach x (list email outlook) (and x (vlax-release-object x)))
    Thanks Brian
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,477
    Use ronjonp's subfunction from the provided link:
    Code:
    ;; Usage:
    ; (rjp-OutlookMessage
    ;  "johndoe@nowhere.com;johndoewife@nowhere.com"                         ;; email address (multiple separated by semicolon)
    ;  "Test Email"                                                          ;; Subject
    ;  '("C:\\test\\file1.txt" "C:\\test\\file2.txt" "C:\\test\\file3.txt")  ;; Attachments as a list of strings
    ;  "Nothing to read here :)"                                             ;; Text in body of email
    ;  nil        ;; nil will open email to edit...T will send email in the background
    (defun rjp-OutlookMessage (To Subject AttachmentList Body Send / objMail objOL)
      (and
        (setq objOL (vlax-get-or-create-object "Outlook.Application"))
        (setq objMail (vlax-invoke-method objOL 'CreateItem 0))
          (vlax-put objMail 'To To)
          (vlax-put objMail 'Subject Subject)
          (vlax-put objMail 'Body Body)
          (foreach file AttachmentList (vl-catch-all-apply 'vlax-invoke (list (vlax-get objMail 'Attachments) 'Add file)) )
          (if send (vlax-invoke objMail 'Send) (vlax-invoke objMail 'Display :vlax-true) )
          (vlax-release-object objOL)
          (vlax-release-object objMail)
        ); progn
      ); and
    ); defun rjp-OutlookMessage
    I just modified the formatting per my own taste.
  1. Send a drawing via email
    By Lithium in forum AutoCAD Beginners' Area
    Last Post: 10th Aug 2013, 08:30 am
  2. Open and send email using visual lisp
    By Small Fish in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jul 2011, 03:28 pm
  3. Why my email
    By Adesu in forum AutoCAD Drawing Management & Output
    Last Post: 26th Feb 2004, 03:21 am
Tags for this Thread
