Results 1 to 6 of 6
    Full Member
    Architecture 2017
    Feb 2016
    athens,georgia
    27
    Default Location of action recorder button?
    Can someone please tell me where the action recorder button is located in autocad mech 2017? In vanilla autocad it is located on the manage tab at the far left- but i dont see it in autocad machanical.
    AutoCAD 2013
    Nov 2011
    5,973
    I don't use MEP, nor the ribbon, so this may not help you, but in Autocad Vanilla, it can also be found in the right click menu, or in the TOOLS dropdown menu, on the Menu Bar.
    And here I thought I was the only one who enjoyed this great functionality!
    You can also call it at the commandline, with ACTRECORD.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,796
    AFAIK it should be there, have you messed around with the CUI any?
    Maybe a Repair will fix it.
    Full Member
    Architecture 2017
    Feb 2016
    athens,georgia
    27
    Dadgad you were right- I accessed that command by typing ACTRECORD in the command line ( I am using the student version of autocad mecahanical 2017 and that was the only way I could access it); however when I did type it in I received a notification that the ACTRECORD command has been disabled. So now my question is how do I enable it? This autocad mechanical 2017 that I'm using is part of the student version of the Product Design Suite if that helps to narrow down a solution.
    SLW210 that was a very good suggestion and I did briefly look in the CUI but there was SO MANY different files and commands that I didnt go through all of them as I had already found out that the command was disabled, however I do plan on exploring in detail the CUI.
  5. #5
    AutoCAD 2013
    Nov 2011
    5,973
    Quote Originally Posted by brite1212 View Post
    I am not sure how or why it would have been disabled in the software.
    Likely there is a good reason.
    Looking in the cui, I found it at the bottom left under All Commands, and have created a screenshot of the macro associated with the command.
    The macro to stop the Action recorder replaces RECORD with STOP.
    This does not constitute an informed suggestion that you want to do this, I am merely trying to help, by moving a little information around.
  6. #6
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,796
    I would run a repair on it, should be NO difference between Student and Purchased Retail version in this regard.
  1. Replies: 0
    Last Post: 16th Mar 2011, 04:29 pm
  2. Action Recorder macro
    By mahesh_neelam in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jul 2010, 12:14 pm
  3. Any one can help me to do Script & Action Recorder
    By ruksi in forum AutoCAD General
    Last Post: 22nd Feb 2010, 03:01 am
  4. Action Recorder
    By happyunited in forum AutoCAD General
    Last Post: 2nd Oct 2009, 04:56 pm
  5. Error message with Action recorder
    By epond in forum AutoCAD General
    Last Post: 11th Feb 2009, 07:41 pm
