Results 1 to 8 of 8
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    Default Flatten a drawing
    hi
    using autocad 2017,
    having a drawing with unwanted Z axes.
    the drawing contains nearly all kinds of objects.
    tried using Flatten but without success
    (drawing attached)
    ay idea?
    Tx
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,154
    I had this problem once. You have two main choices. One, write a routine to replace every Z coordinate with zero. Two, use Quick Select, use Properties to get each type of object, and manually type zeroes into the Z coordinates. Unless you have a similar routine already, it's probably quicker to use the second option. And by now, you've had time to do it.
    breaking AutoCAD on a regular basis since 1991
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    Quote Originally Posted by CyberAngel View Post
    I downloaded the drawing and tried this. It is possible even though I am only running LT, and FLATTEN doesn't exist in LT.
    It would have been easy if there were not a couple three dozen block definitions with content that had varying "Z" values. It would have required opening each block in the block editor and changing the Z there. Too much. Attribute def's with a Z of -53,896.087 units, while the rest of the block was at zero Z? Seriously? That drawing is not even 3D, or shouldn't be, and it is a meZZ. a hot meZZ.
    There were also objects 50 k and 100 k units up too. cheeeze looeeeze!
    And the text objects and dimensions, very hard to manipulate manually in Properties. What's with all the oddball scale factors? It was a fun exercise but got tedious and the results were kinda messed up so I didn't save it. Wouldn't want the OP to overwrite a good drawing with my bad one by accident.
    And everything in the drawing is miles from 0,0,0.
    I don't even want to know why a lot of the text is backwards, really backwards. Some of it only looks backwards because it is not an English character set, but the rest of it is flat out backwards. Maybe it is Davinci Code?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,638
    Dana: Are you saying that whoever created the drawing should seriously think about getting into another line of work?
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    Lots of blocks with the items inside having z values, you'll need to find a LISP to set everything inside blocks and maybe even some nested blocks to have Z=0, then you can set the rest to Z=0.
    Yes, this drawing was poorly done.
  6. #6
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    I used the old 0,0,1e99 method, found in this post: http://www.cadtutor.net/forum/showth...l=1#post303014
    This took care of all the objects not in blocks. I then used QSELECT to select all Line and Polyline elements, in which I set the Thickness value to zero. All that is left was the blocks, which were few.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  7. #7
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,154
    Quote Originally Posted by Dana W View Post
    I see what you did there.
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    Well, not a line of work exactly...
  1. Can't FLATTEN a particular drawing
    By bababarghi in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jan 2016, 11:22 am
  2. Please help flatten my drawing
    By kizaerf in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2014, 12:53 pm
  3. How do i flatten a drawing?
    By mattbarb in forum AutoCAD General
    Last Post: 28th May 2008, 07:22 pm
  4. flatten drawing to 2d
    By jkaran in forum AutoCAD Drawing Management & Output
    Last Post: 12th Dec 2005, 09:10 pm
  5. Flatten a drawing
    By Vince0115 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2005, 09:36 pm
