Results 1 to 5 of 5
    Junior Member
    Education
    AutoCAD 2017
    Jan 2017
    10
    Default How do I make this into 3D with a taper?
    This is a very simplified example, but I have a base to a device that is angled. How would I extrude (or whatever method you recommend) to make it 3D?
    There is actually other "stuff" on top of this, but I just drew up some blocks so you understood what I was dealing with.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Draw the LEFT View and Extrude the distance you need.
    Forum Newbie
    AutoCAD 2015
    Dec 2015
    3
    it's so easy to make, without using the taper command , what you need to stand on the left side elevation and draw this triangle and then forced extrude with the value of wide of the rectangle of top view above then you need to move it again to rear elevation and draw again the opening in this view and make extrude for short distance and make subtract , then you will got you looking for, hope I help you
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    The openings at the end of the triangle can also be created using the PRESSPULL command.
  5. #5
    AutoCAD 2013
    Nov 2011
    6,056
    +1 PRESSPULL...survey sez, that's the #1 ANSWER!
  1. Cannot taper using solidedit
    By Ninoshka in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Nov 2014, 03:34 pm
  2. How to dim slope and taper
    By lucas3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2014, 07:37 am
  3. 3d Taper Troubles
    By CiCAD in forum AutoCAD General
    Last Post: 25th Jan 2011, 03:27 am
  4. How to taper faces
    By humaironline in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Aug 2009, 08:17 am
  5. Can i taper a linetype?
    By Coey in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Feb 2008, 06:40 pm
