Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,302
    Default 3D Assistance Needed for Odd Shape
    I've got an odd shape here that I want to turn into a 3D model. It's a round object with lots of irregular curves. I do pretty good with 3D objects that are not so complex, but I really don't know how to do this one. Extrude will most likely not work since the diameters change so much and it's not a flat bar. I've thought how revolve might work, but that too is not what I think will work.
    It's deja vu, all over again.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I'm thinking LOFT but you'll have to create all the necessary circles to adequately cover the range of diameters that would be needed.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Not really sure but is this what your after had no real problems making but will await your response.
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,302
    Thanks. I think ReMark has got what I need. I'll study up on doing a loft, and he's right, I'm going to need lots of circles to get it done. And as always, BIGAL you got some cool stuff there. But what I should have said is that this thing is shaped kind of like a dildo, if you know what I mean.
  5. #5
    AutoCAD 2013
    Nov 2011
    6,056
    I would suggest Loft with the PATH option.
    Might need to do the fluid reservoir tip outboard, and add it, not sure how the loft to point would handle that.
    I shouldn't think you will need all that many circles, as long as you have a Path.
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Understand a banana cut in half. Its a Nurb type question rotating and changing from a positive to a negative curve.
  7. #7
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by Bill Tillman View Post
    Bill, I played around with this a bit, created a spline to use as a path.
    It ain't perfect, but it might help you come to grips with a better way to do it.
    I added some circles, after earlier tries.
    The loft on the right is the last one I did, and it is based on the linework entities to the left of it.
    It was generated with the Path option.
    In the screenshot, you can see that if the lofted 3D Solid is selected, after the fact, there is a drop down menu available to alter the surface treatment, which affects the overall shape.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Dadgad I thought the same idea a series of circles joining the two edges, just my 3D skills are pretty basic.
    Reading another post referring to Fusion 360 the reference was "Freeform modeling" this may be more suitable for this type of shape.
  9. #9
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by BIGAL View Post
    No doubt this is how ReMark envisioned doing it in his earlier post.
    Given that Bill had already supplied the .dwg with the shape, it was pretty straight forward.
    I started by drawing a number of straight polylines across the shape, each of them to the Perpendicular snap on the far side.
    I then drew circles centered on the midpoint of each of these lines, with the radius defined by snapping to either of the polyline endpoints.
    Each of these circles was 3D Rotated using the 2Points option, and the polyline endpoints by 90 degrees.
    I then drew a SPLINE, defined by the midpoint of each of the polylines (or the center snaps of the circles, as they should be the same).
    I enjoy doing most modeling from an isometric perspective, as it makes it easier to see what you are picking, although in some instances, it may not display the completed 3D Solid as accurately as an ortho view. I also tend to keep a copy of the defining linework to one side, in case I want or need it again.
    Start the LOFT command, and pick the circles in lofting order, then I used the PATH option, and selected the Spline as the path.
    By using the perpendicular snap when creating the defining polylines, the orientations of the individual circles conform to the overall design intention, as I understand it.
    If they were parallel to the XY plane, that would not be the case.
    Probably the Reservoir tip is the hardest part of it, and I only spent a minute on it, nor did I do it justice.
    I have never used Fusion 360, but based on the rave reviews by Shift, and other forum members, you may well be right about the Freeform Modeling capability.
    I have only ever modeled 3D Solids, never meshes, surfaces nor nurbs, one of which might be more appropriate for this, not sure.
    Offended by my failure to address the Reservoir tip a tad more diligently, I revisited it.
    Suffice it to say, that I improved the overall loft again by adding a few new circles, yet again, and I fixed the tip.
    Honey let me introduce you, to my red headed mend.
    It is now officially time for me to step away from the magic box!
  10. #10
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,302
    Thanks everyone. I'm just getting back to this method and will study how you modeled it. I think I understand but the first couple attempts I made at it did not function correctly for the loft. In any case, I was able to place the 3D model into my model and it looks great. Kind of a weird shape with nothing uniformly curved though.
  1. Mechanical Desktop 6.0 PP SP4 Assistance needed
    By brian3163 in forum Mechanical & MDT
    Last Post: 12th Jul 2012, 10:24 pm
  2. how to create a ellipsis or circle of needed shape?
    By vikidaya in forum AutoCAD Beginners' Area
    Last Post: 5th Aug 2010, 12:03 am
  3. How do you draw a shape on the Z axis using the shape tool?
    By cvriv.charles in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Feb 2009, 10:47 am
  4. S.O.S. - LISP &/or VBA Assistance Needed
    By Broman in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Nov 2006, 09:35 pm
