Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by Bill Tillman View Post
    Kind of a weird shape with nothing uniformly curved though.
    Isn't that how it was supposed to look?
    Presumably the diameters of the circles are meant to be somewhat random, as that was my impression from your original linework.
    If they are meant to be the same diameters, that would be easy to do.
  2. #12
    Senior Member ammobake's Avatar
    ammobake's Computer Details
    Windows 7 Pro 64bit
    HP 2240 SFF Workstation
    HP
    Intel Xeon CPU E3-1225 v5 @ 3.30ghz, 3.30ghz
    18 GB RAM
    Nvidia NVS 510
    Confidential
    Confidential
    4 total (2 - 27 in monitors below, 2- 22 in monitors on top)
    Construction
    ammobake's Discipline Details
    CAD Drafting & Architecutural Design (gov/military)
    Construction
    AutoCAD 2017
    Mar 2008
    Fairbanks, Alaska
    206
    given you're dealing with circles (closed) one could simply draw ruled surfaces (command: rulesurf) to draw the meshes automatically between each circle?
    Surftab command will let you experiment with the number of surface tabulations before using the rulesurf command.
    Loft could also work but would almost be too complicated in my opinion.
    -ChriS
  3. #13
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    Quote Originally Posted by ammobake View Post
    If you use Rulesurf you're going to end up with a series of straight cylinders, not a single organic shape like what is shown in Dadgad's images.
    In the image below, I used Rulesurf for the object on the left and Loft for the object on the right. Not only was Loft easier and faster than Rulesurf, but it is smooth and organic in appearance and it's all one solid piece as opposed to the linear and faceted shape of the Rulesurf object which is made up of 3 separate hollow pieces.
    For my money, Loft is the way to go.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  4. #14
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by Cad64 View Post
    Additionally, once created you can still affect the overall shape by changing the surface treatment of the completed lofted object, as I mentioned previously.
  5. #15
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    The process is cumbersome but a more seamless surface can be had via Control Vertex modeling of a nurbs surface. SurfSculpt to make it a 3D solid.
  6. #16
    AutoCAD 2013
    Nov 2011
    6,056
    That looks really good SEANT, I figured there would be another more modern way to do it, my techniques on such things tend to be pretty old school.
  7. #17
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Seant, that's really cool. Would you be able to explain a little more in detail how you did that? I'm totally new to things like "Control Vertex modeling of a nurbs surface" and "SurfSculpt".
    It's deja vu, all over again.
  8. #18
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Here's a quick screencast demonstrating the general procedure for processing a revolved surface to allow for vertex editing. Part of the problem regarding manipulation is the selection methods have to coordinate Object selection, to highlight the Vertices, then a vertex filter, to grab the group of vertices for any particular operation.
    The right click menu whilst vertex editing allows for Move, Rotate, Scale, and Stretch (same as move).
    Once the surface shape was as needed, a "Planar Surface" can be created (aligned with the World XZ plane in my example) and used to cap the curvy surface via the SurfSculp command.
    http://autode.sk/2q3qnKx
  9. #19
    Windows 7 Pro 64bit
    HP
    18 GB RAM
    Nvidia NVS 510
    Confidential
    Confidential
    Construction
    Construction
    AutoCAD 2017
    Mar 2008
    Fairbanks, Alaska
    206
    Surftab was an example given the ring pic above that I assumed was what you were trying to model (my bad). BUT there are other mesh commands that can draw the mesh thru multiple closed objects that would be able to emulate your desired result at the very least and would be easier yet than loft in my humble opinion...
    If you have an actual model or 3d example of what you are trying to draw in Autocad you can always use Recap 360 to take multiple photos of the object which will be able to create a complete 3d model of the object which basically gets emailed to you after it is processed by Autodesk.
    OR, and I'm just using this as an example, if you wanted you could model it from clay, then use this feature to create a complete 3d model of the object that would get emailed to you as a DWG file.
    It's possible is all I'm saying...
    -ChriS
  1. Mechanical Desktop 6.0 PP SP4 Assistance needed
    By brian3163 in forum Mechanical & MDT
    Last Post: 12th Jul 2012, 10:24 pm
  2. how to create a ellipsis or circle of needed shape?
    By vikidaya in forum AutoCAD Beginners' Area
    Last Post: 5th Aug 2010, 12:03 am
  3. How do you draw a shape on the Z axis using the shape tool?
    By cvriv.charles in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Feb 2009, 10:47 am
  4. S.O.S. - LISP &/or VBA Assistance Needed
    By Broman in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Nov 2006, 09:35 pm
