Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,456
    Thanks Lee!
    It looks quite useful, for example finding the nearest/furthest distance between point list and origin:
    Code:
    _$ (extremum '(lambda ( a b ) (< (distance '(0. 0. 0.) a)(distance '(0. 0. 0.) b))) '((1.2 5.7 8.3) (9.4 2.6 0.3) (5.7 6.6 7.2)))
    (9.4 2.6 0.3)
    More expanded idea for usage would be constructing assoc list of (distN . enameN) to find the nearest/furthest entity.
    I see it as a combination between vl-some and vl-sort (like doing something like: (vl-some 'min lst) ).
    I'd say good job!
  2. #12
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Thanks Grrr.
    In practice however, the function could be optimised, as the result of the comparison function when applied to the current extremum would be known and would therefore not need to be recalculated for each item in the list (this is demonstrated by the 'zmx' & 'zmi' variables used in my earlier function which returns the points with minimum & maximum z-coordinate values). This optimisation is not possible when an arbitrary comparison function is used.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  1. Want to draw a series of "X" or "l l" lines between 2 points (weld lines)
    By p0peye in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2013, 10:58 pm
  2. Replies: 1
    Last Post: 7th Feb 2013, 10:28 pm
  3. Replies: 10
    Last Post: 29th Jan 2013, 08:38 pm
  4. selected objects not showing up as "dashed"
    By streetmike in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Jun 2010, 08:00 pm
  5. Lisp: Extract highest/lowest value from a list
    By ajs in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2009, 02:58 am
Tags for this Thread
