Table with field
Hi,
I have a table. The text in the table is the field associated with the block.
When I copy that table and then a block to another drawing the text filed come to be as ##.
Could anyone please help me to resolve this issue.
Update the field. UPDATEFIELD
Note: When the DEMANDLOAD system variable is set to 2, fields cannot be updated until you use FIELD or UPDATEFIELD.
Look up FIELDS in AutoCAD Help for more information and/or post your drawing with the block and the field.
P.S. You may need to check on FIELDEVAL value.
