Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Default draw multiple lines to a central origin location
    Quite often I draw lines from many entities at different location to a central origin point.
    Instead of drawing them 1 bat a time, Is there a lisp that I can click those entities with the last click for the central origin point like the picture below
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,109
    Hi,
    What are the names of these entities? Points, Blocks, Circles .... etc. So can you list them down here?
    Senior Member
    AutoCAD 2016
    Jan 2012
    160
    Draw the first line, select line and then the grip point att the end, right click and select copy.
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Quote Originally Posted by Tharwat View Post
    Hi,
    Tharwat, to be clearer, its not so much the type of entities, rather it is more like a kind of marker or marking for me or my workers to refer to multiple location in the drawing.
    So as an example of how the lisp were to run is (base on the photo in the 1st post)
    1)I will be clicking on multiple location in the drawing (1st click, 2nd click, 3rd click & 4th click)
    2)for the last click I will click a distance away from all the previous clicks then press ENTER
    3)lisp will then draw all the line from all the clicks (1st click to 4th click) to the last click (which will be the central location)
  5. #5
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Quote Originally Posted by guran View Post
    There is no copy option at the grip point.
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,109
    Something like this?
    Code:
    (defun c:Test (/ int inp pt1 lst pt2)
      ;;  Tharwat - Date: 18.4.2017  ;;
      (setq int 0
            inp '("1st" "2nd" "3rd" "4th" "Base")
      (while
        (and (< int 5)
             (setq pt1 (getpoint (strcat "\nSpecify " (nth int inp) " Point :")))
         (setq int (1+ int)
               lst (cons pt1 lst)
      (and (= (length lst) 5)
           (foreach p (cdr lst) (entmake (list '(0 . "LINE") (cons 10 (car lst)) (cons 11 p)))
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,581
    Quote Originally Posted by tive29 View Post
    Read the post carefully, select the line and then the grip point at the end, RIGHT CLICK and select copy. Instead of the right click you can type C for copy at that point as seen in the command line options after the grip is selected.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  8. #8
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,243
    Tharwat, I think you understood it literally... I think that OP means input as much points as needed - while loop is needed and when it's terminated, user should pick base point and then routine should connect all points from stored list of points obtained while looping with base one...
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  9. #9
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,109
    Quote Originally Posted by marko_ribar View Post
    That's exactly what I thought when I was readying the 1st post but it seems that they insist on four points than looping with a base point at the conclusion.
    Have a read about post# 4
  10. #10
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Tharwat, apologies, I meant the 4 clicks as an example. it will be many clicks as marko has mention with the last click as the origin after pressing ENTER.
  1. Help with Hatch Origin Location Program
    By 3dwannab in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Mar 2017, 01:24 am
  2. Replies: 11
    Last Post: 23rd Jun 2016, 09:42 pm
  3. How to check the origin location of an existing hatch?
    By vernonlee in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 18th Mar 2015, 04:34 am
  4. drawing a line central to two paralel lines
    By CADsince07 in forum AutoCAD General
    Last Post: 14th Dec 2011, 05:58 pm
  5. Controlling toolpalets from a central location
    By raj banerjee in forum Revit General
    Last Post: 23rd Nov 2011, 12:39 pm
