Bill Tillman Posted April 18, 2017 Share Posted April 18, 2017 I'm printing some 24 x 36 sheets using the BluebeamPDF driver which came with my Bluebeam software. The trouble is when printing the entire layout and I do a Preview, the lines get very muddy. The lineweight for the lines is set to "Default" so I'm not sure what's happening or if there is anything which can be done. When I zoom in real close and print just a window I get much better results and the lines, while weighted are at least clear and legible. Obviously I could use some advice on lineweights. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 19, 2017 Share Posted April 19, 2017 Sounds like you might want to unselect print lineweights in your printer setup. Quote Link to comment Share on other sites More sharing options...
tombu Posted April 19, 2017 Share Posted April 19, 2017 What's your LWDEFAULT set to? The initial value is 25, but I keep mine set at 15. Quote Link to comment Share on other sites More sharing options...
