Results 1 to 3 of 3
    Forum Newbie
    Civil
    AutoCAD 2016
    Apr 2017
    1
    Default Create a line with Corresponding Dimension
    Hi, I was wondering if i could use two commands, line and dimlinear, in a single lisp file. this one i have measures a line you set with two points and creates a line that is a 1/3 in length of the distance between the two points. I want to add dimension line that will be 500 units above the created line. Any help would be very much appreciated. Thank you in advance.
    (defun c:aa ()
    (setq po1 (getpoint "Pick first point:")
    po2 (getpoint po1 "Pick second point:")
    le (/ (distance po1 po2) 3)
    po3 (polar po1 (angle po1 po2) le))
    (entmake (list '(0 . "LINE") (cons 10 po1) (cons 11 po3)))
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    Just look at the steps in creating the dimension write them down, you need an extra point this is 500 units above po1 use a polar with (+ (/ pi 2.0) (angle po1 po2)). As a hint when you type dimalign when it asks for a start point type !po1 then type !po3 this will use the two lisp points previously created.
  1. Change dimension line length when text is outside / beside dimension
    By mane222 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Jun 2016, 03:36 pm
  2. How to create an angled line from a linear dimension ...
    By JDCOOK in forum AutoCAD Beginners' Area
    Last Post: 19th Dec 2014, 03:03 pm
  3. Replies: 9
    Last Post: 17th Sep 2011, 02:09 pm
  4. insert dimension measurment field on dimension line
    By bcastillo in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2009, 04:32 am
  5. Dimension - remove dimension line but not arrows
    By jkristia in forum AutoCAD Beginners' Area
    Last Post: 7th Nov 2008, 04:24 pm
Tags for this Thread
