Results 1 to 10 of 10
    Junior Member
    AutoCAD 2002
    Jun 2013
    11
    Default Civil 3D Drawing with XRefs is bogging down
    Hi there, hoping someone can help me out. I don't use autocad much, just for my construction staking projects. I have a simple street project going, and the designers have provided me with the edgelines drawing. I have Xref'ed in the storm sewer and sanitary drawings. When I add a label using the station and offset from alignment tool, the drawing locks up for about 8-10 seconds, and then everything is fine. I will add hundreds of labels for my layout, and this is just annoying to sit and wait for it to continue. What's going on!
    I have other projects that I have worked on with autocad, and this issue doesn't happen on those jobs. Maybe it's something to do with how I attached the xrefs?
    Thanks for any insight to this.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    Have you checked that all dwgs are on the same co-ordinates or are you scaling and rotating the xrefs ?
    Junior Member
    AutoCAD 2002
    Jun 2013
    11
    All drawings are on the same coordinate system Al.
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    How much RAM do you have? It may be that you have run out of RAM and AutoCAD is having to cache the drawings on your hard drive instead.
  5. #5
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    I haven't used Civil 3D in years but does a separate ribbon bar activate when you use the tool. Sometimes command specific ribbons activate when using a tool and their load time is atrocious. This can usually be disabled in the CUI.
  6. #6
    Junior Member
    AutoCAD 2002
    Jun 2013
    11
    Thanks for the replies iconeo. I don't think it has to do with my RAM. This has to be something with this specific drawing. I can open another drawing and it works like a dream. One of the xrefs has a lot of points loaded in it, but I wouldn't think that would slow it down.
    I don't have a clue what the CUI is! Just a part timer here.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,129
    Are the Xrefs local or on a network?
    P.S.
    I moved your thread to the Civil 3D & LDD Forum.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    CIV3D still suffers once you get into big data sets, how many points in the xref ? I have 200k+ and you notice the impact.
    Like SLW210 we have our temp drives set to a c:\acadtemp directory to stop hammering the network server. DWGS are saved to server.
    Try also attach the points into the dwg rather than a xref see if that helps.
  9. #9
    Junior Member
    AutoCAD 2002
    Jun 2013
    11
    Xrefs are "local", I guess. I have one home office computer.
    There are only 200-300 points in the xref drawing. They are points created by the designer for layout of the sanitary and water mains. I am not using these points at all, as I do my layout using station and offset from alignments.
    I added these xrefs as an "overlay", not as an "attachment". Wondering if this has something to do with it?
  10. #10
    Junior Member
    AutoCAD 2002
    Jun 2013
    11
    Fixed the problem. I finally got a hold of my autocad rep, and he helped me out. It had everything to do with the xref files. I had to click on the xref layer in layer properties, and hit the invert filter button. Now, when I want to move a station and offset label, it works within one second, not 8 seconds.
  1. drawing has old xrefs I want to preserve.....
    By dumfatnhappy in forum AutoCAD General
    Last Post: 6th Feb 2013, 09:34 pm
  2. Civil 3D 2010 and xrefs
    By CivilKrystal in forum Civil 3D & LDD
    Last Post: 25th Nov 2010, 03:28 am
  3. Osnaps Not Working on XREFS, ACAD Civil 2010
    By Dou9las in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Mar 2010, 09:16 pm
  4. Drawing Amendments and Xrefs
    By Primal Scientist in forum AutoCAD Drawing Management & Output
    Last Post: 26th Mar 2008, 12:45 pm
  5. Merging all xrefs into a drawing?
    By spittle in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jan 2008, 03:30 pm
