Results 1 to 7 of 7
    Full Member
    AutoCAD 2011
    Jul 2009
    89
    Default Arc tracing problem
    I am trying to trace a curved area of an inserted image,using the 3 point arc command.
    When I try to insert the 2nd point of the arc,a dotted line appears with an extension statement and a marker,which overrides my selection,why does this occur and how do I get rid of it.??
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Can you show us what you are experiencing?
    Drafting is a breeze.
    AutoCAD 2013
    Nov 2011
    5,985
    If you snap to the end points of the arc, you can then grip stretch the mid point grip of the arc to the line which you are tracing, with the perpendicular snap.
    Full Member
    AutoCAD 2011
    Jul 2009
    89
    Quote Originally Posted by RobDraw View Post
    This is a screen dump showing the problem.
    I have selected a point on the image and the screen shows the resultant location of the point.Trying to compensate won't work,as the revised location varies?
  5. #5
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,152
    Not sure what the problem is. You've put in two points, you only have to give it the third point to get your arc. The dotted line tells you where the arc might go based on the two points you've already given.
    If that's not the real problem, you may be having trouble because the entity you're tracing isn't an arc but a spiral, that is, the angle changes along its length.
    breaking AutoCAD on a regular basis since 1991
  6. #6
    Full Member
    AutoCAD 2011
    Jul 2009
    89
    Quote Originally Posted by CyberAngel View Post
    I have picked only the 1st point of the 3,I am being driven,for some reason,to the 2nd point-------!!!!!!
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,870
    Have you tried continuing through with your selections?
    Can you post the .dwg?
  1. Tracing In CAD
    By Chris_Hebden in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jun 2011, 01:06 pm
  2. Tracing
    By Big G in forum AutoCAD General
    Last Post: 11th Nov 2010, 03:00 am
  3. Tracing?!!!
    By GypsyQueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Jan 2009, 02:07 pm
  4. Tracing???
    By Grumple in forum AutoCAD Beginners' Area
    Last Post: 2nd Jul 2008, 01:46 pm
  5. Tips for tracing please
    By anthonyC in forum AutoCAD Beginners' Area
    Last Post: 19th Nov 2006, 09:43 pm
