Chilidawg Posted April 25, 2017 Share Posted April 25, 2017 When working in the Sheet set manager, if you are in the dialog box to rename and renumber the sheets, it gives you the option to change the layout tab to the sheet title listed in the SSM. Am I the only one who thinks that this option would be far more useful if instead of renaming the layout tab to match the sheet title, you could rename the layout tab to match the sheet number? Who wants a layout tab that's 20+ characters long? If your sheets are numbered using a standard system, you should have a pretty good idea what's on the sheet by the number alone. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted May 2, 2017 Share Posted May 2, 2017 It's a personal preference but I agree. Using the sheet number is an easier way of naming a sheet by using the tag. Quote Link to comment Share on other sites More sharing options...
