Results 1 to 9 of 9
Thread: xref linetypes
    Junior Member
    AutoCAD 2013
    Jan 2013
    13
    Default xref linetypes
    how to resolve xref linetypes in autocad 2017
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Can you be a little more specific?
    Drafting is a breeze.
    Junior Member
    AutoCAD 2013
    Jan 2013
    13
    Line types not showing up dashed in drawing with xref overlay in autocad 2017 yet showing up dashed in autocad 2013
    Could someone explain why please
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Are you comparing using the same file?
    What is the name of the linetype?
    What have you ruled out so far?
  5. #5
    Junior Member
    AutoCAD 2013
    Jan 2013
    13
    Yes using same drawing and xref overlay
    Have tried visretain, xref override, ltscale, msltscale, etc
    Tried everything with no luck
    Could it be something to do with autocad 2017
    No problems with other versions of autocad
    Autocad 2011 Lt, autocad 2013 no problem
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    It's not a problem with 2017 per say but rather a setting is different and you have not found it yet.
    Is it a particular line type or is it all line types?
  7. #7
    Junior Member
    AutoCAD 2013
    Jan 2013
    13
    Only line types which I have as bylayer in base xref drawing and alter to hidden in drawing with xref overlay
  8. #8
    Forum Newbie
    Construction
    Architecture 2015
    Jul 2017
    1
    I have no idea of it.
  9. #9
    Senior Member dtkell's Avatar
    dtkell's Computer Details
    Win7
    Intel I5 4670
    16mb
    Civil
    dtkell's Discipline Details
    Drafter/Designer
    Civil
    AutoCAD 2014
    Dec 2006
    San Diego, CA, USA
    153
    Might want to check your annotation scale and your 'msltscale' settings.
  1. xref linetypes autocad 2017
    By MCacic in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Apr 2017, 02:58 am
  2. Lingering xref linetypes
    By yport in forum AutoCAD LT
    Last Post: 5th Nov 2015, 06:40 pm
  3. Filter XREF Linetypes?
    By Prospectmp in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Sep 2011, 06:25 pm
  4. Bound XREF Linetypes
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2009, 07:20 pm
  5. XREF's and linetypes
    By EMS_0525 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Mar 2009, 03:24 pm
