Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Sweep Me Not
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Default Sweep Me Not
    Can anyone tell me why I cannot sweep this one? The rectangular object at the bottom of the stairs is going to be the handrail. I have created a spline for it to follow up the stairs. But when I try to sweep it along this path, it will not work.
    It's deja vu, all over again.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,595
    I could be totally wrong here but I took a different approach and made a rough 3dpoly from your spline values but shape was weird ? Added a circle and extruded ok.
    You may have to do a 3d poly with straights and arcs. Need to set up some UCS's so can flip to correct plane adding section and fillets.
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by BIGAL View Post
    That is how I would do it too, BIGAL.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,595
    Had a bit of a google search and could not find any easy way to do, Revit and Architecture have handrails. One way is to make each section on planar level extrude then use a union or fillet to join together. The riser rail meets the curve at a common TP but you actually need a tiny radius equal to rail size. Its almost a lisp type answer rise run fillet and keep creating. I am sure if I am wrong about this better 3d people than me will jump in pretty quick.
    Look at the image, union the riser to the horizontal rail
  5. #5
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    292
    Try out
    PEDIT3D.vlx
    (free download from www.ant-ares.de)
    and get the attached result
    Regards
    Jochen
    PS.: Made in BricsCAD but works for AutoCAD too
  6. #6
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Thanks all. BIGAL, I too found that unless I broke the polyline up into sections I couldn't get this to work all the way up. The trouble still is in the upper left corner when you look at this in plan. The handrail elevates across the top of the plan view by 16cm thus when the SWEEP gets to that 90° corner I hit the wall with AutoCAD trying to rotated the rectangular shaped handrail. A round one will work fine because it's symmetrical along all 360° of it's profile. As I understand it, other versions of AutoCAD can handle this twisting if you will. But AutoCAD Professional does not. Anyway, this gets me close enough for this project. Not building a Swiss watch, just a handrail.
  7. #7
    Senior Member ROBP's Avatar
    ROBP's Computer Details
    WINDOWS 10 PRO
    Eurocom
    IINTEL i7-6700K- 4.00GHz
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    ROBP's Discipline Details
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    works fine here
    Creativity is intelligence having fun
  8. #8
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    ROBP: Thanks but it appears you're using MEP 2018, vs mine which is AutoCAD 2014 Professional. I'll get by for now as this 3D exercise was just for a dog and pony show. Time to update again.
  9. #9
    WINDOWS 10 PRO
    Eurocom
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    Quote Originally Posted by Bill Tillman View Post
    Yes just getting the hang of Mep for now but i had 2014 full 4 years ago and i recall that the sweep did work at the time.
    Hopefully you where able to open it i can do a save to earlier version if needed just let me know i will repost.
    Btw the handrail at the right far side need to follow the landing and will need to be reworked and be raised to match the height to follow like the first landing one on the left.
    Best
    Robert
    Awaiting your correction and will sweep again no problem
  10. #10
    WINDOWS 10 PRO
    Eurocom
    64 GB
    K5100M
    1 TB
    1 TB
    N/A
    P&ID
    Powerhouse designer
    P&ID
    MEP 2018
    Oct 2013
    Montreal, Canada
    344
    TrueView was always helpfull when newer version needed to be converted prior update on my side.
  1. Sweep
    By Lentezza in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Mar 2013, 06:07 pm
  2. Unable to sweep object when attempting helical sweep for pipe thread
    By eKretz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Dec 2012, 02:26 pm
  3. Why can't I sweep this?
    By the downing effect in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Nov 2012, 03:32 am
  4. Always Use Sweep 90's
    By Kremer in forum MEP
    Last Post: 14th Jan 2011, 09:36 pm
  5. Sweep
    By ausmods in forum Autodesk Inventor
    Last Post: 12th May 2009, 12:11 pm
