Results 1 to 8 of 8
    Full Member jaff's Avatar
    jaff's Computer Details
    Windows 10 Professional
    Dell OptiPlex 5040
    Version 10.0.10586 Build 10586
    Processor Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz, 3192 Mhz, 4 Core(s), 4 Logical Processor(s)
    Installed Physical Memory (RAM) 4.00 GB
    Adapter Type AMD Radeon Graphics Processor (0x6610), Advanced Micro Devices, Inc. compatible
    Size 453.24 GB NTFS (486,661,943,296 bytes)
    Dell E2213H
    Structural
    jaff's Discipline Details
    Engineer
    Structural
    Residencial Design, Low Rise Building Design
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Default Dynamic block problem keeping objects centered
    I would like to keep the objects in the block centered but I have no success. Can anyone please tell me how to make the dynamic block work properly. Every time I change a shape other objects will not follow.
    Thanks,
    p.s.: I am using ACADLT 2017 and I am guessing that there is a tool that I am probably missing to make the dyn. block work properly, is that correct?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    You cannot stretch a circle, not in model space, also not in a block, and your stretch area for the polygon, is not placed where it will do anything, although you can stretch a polygon it will be mis-shapen when you do, for this geometry your best option would be a scale action, I would use a linear parameter based at the center of the block.
    Dell OptiPlex 5040
    Dell E2213H
    Structural
    Engineer
    Structural
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Default thanks steven-g
    I appreciate your comments. I will try your suggestions.
    Dell OptiPlex 5040
    Dell E2213H
    Structural
    Engineer
    Structural
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Steven-g
    I recreate the block using the scale action but I cannot keep the geometries relative to the center position. Would you tell me how to make the block work properly. See attached. Thanks.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    Why not draw each option and use Visibility State?
    You really should be posting these questions in the AutoCAD LT Forum, since Dynamic Blocks have to be done without constraints in LT.
    I have moved this thread for you.
  6. #6
    Dell OptiPlex 5040
    Dell E2213H
    Structural
    Engineer
    Structural
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Quote Originally Posted by SLW210 View Post
    OK. I will post this questions in the LT.
    The reason I do not want to draw each option its because I want single shapes that can shift to other shapes. I am doing this block as a start up so I can create more blocks with a lot of contents, such steel shapes (AISC shpaes: WF, HSS, ANGLES, ETC.,). Having all these shapes in visibility states will be cumbersome.
    Thanks,
  7. #7
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    I posted a reply this morning, unfortunately it got lost somewhere in the ether. The base point of the linear parameter should be in the center of the block (that's where it scales from).
    I only put in one parameter in the example, just to give the idea.
  8. #8
    Dell OptiPlex 5040
    Dell E2213H
    Structural
    Engineer
    Structural
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Steven-g,
    No problem. I appreciate the help. I will continue to make changes and see where the takes me hopefully I will get it done and move on to my next block. Is there a place where I can upload this file, I would like to share my files with other users.
    Thanks again.
  1. Keeping an object centered and stretched in dynamic block
    By artuiel in forum AutoCAD Drawing Management & Output
    Last Post: 25th Mar 2014, 05:41 pm
  2. Changing Dynamic block name, AND keeping attributes
    By JeremyA1976 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Feb 2014, 08:16 am
  3. problem scaling objects in dynamic block
    By jaff in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jul 2013, 01:41 am
  4. Keeping text centered in a block
    By chelsea1307 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Feb 2010, 09:00 pm
  5. Explode Block Objects by Keeping Attribute Text Values
    By Harun KILIC in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Apr 2007, 09:39 am
