Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Unhappy AutoCAD Annotation Font Size/Scale Error - Bug?
    I wasn't sure which section to post this in as this also affects output as well. Despite it looking good in paper space, it publishes to huge fonts. Print works fine though which is weird.
    I've been having problems with the scale of the new AutoCAD LT 2018. This is the first time I've bumped into such problems. For some reason every time I open any (old) file, save it, and open it again - the font will be huge. Any file that I also create from scratch has the same problem. When I go to save it looks just fine, but when I open it again the fonts are 10x the size.
    http://imgur.com/a/Jmw1W
    I made an album showing the problems I am experiencing.
    https://youtu.be/szWPDrDnrCk
    Here is a video of me showing you how I go about fixing the problem. I don't change anything at all! I just open up annotations and make sure I click the font height section (only clicking nothing else) and click OK. I don't even have to click OK, only clicking the font height section will fix the problem. It is like it forces autocad to reload it or something? I double checked the scale is right and I've also hit REGEN numerous times. I've restarted my computer too. Yet this problem still persists. I open it back up and the font is HUGE. I am at the end of my ropes here. It's annoying having to change the font each and every time I open the file. I'm not sure how to fix it as there doesn't seem to be any solves online.
    Here is another video showing when I save, close my file, and open it again. The fonts are huge again. I've hit regen but it's useless.
    https://youtu.be/VCH71Dq2vrA
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    This is just a guess at what may be doing it, although I am not sure why this would affect the publish output.
    You are using annotative scaling. In modelspace, check the annotative scale pop up list button on your task bar. Change the annotative scale there to get them to look the right size.
    That facility is there in order to adjust the current modelspace viewing scale to what you will see once the model objects are in a viewport in paperspace, at the same scale. It's kind of a preview thing.
    I have also had some weird annotative dimension behavior in AutoCad LT 2018, so there may well be a bit of a bug going on.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Senior Member ammobake's Avatar
    ammobake's Computer Details
    Windows 7 Pro 64bit
    HP 2240 SFF Workstation
    HP
    Intel Xeon CPU E3-1225 v5 @ 3.30ghz, 3.30ghz
    18 GB RAM
    Nvidia NVS 510
    Confidential
    Confidential
    4 total (2 - 27 in monitors below, 2- 22 in monitors on top)
    Construction
    ammobake's Discipline Details
    CAD Drafting & Architecutural Design (gov/military)
    Construction
    AutoCAD 2017
    Mar 2008
    Fairbanks, Alaska
    201
    I agree w/ Dana on this.
    Annotative scaling can be useful in certain situations but about 99% of the time I avoid it like the plague because of these kinds of quirky aspects. It adds a layer of complexity that doesn't need to be there, IMO.
    If you go into the object properties you can remove the annotative property by changing "yes" to "no".
    At that point, the text size you type in will be the size of the text everytime (guaranteed).
    There is a feature for annotative objects where you can have them auto-scale to the layout. This could be playing a role as to why the sizing issue happens as soon as you open the drawing.
    -ChriS
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Annotative scaling is a great tool once you get your head around it. Once you realize how useful and easy it actually is, you might use it 99% of the time.
    Drafting is a breeze.
  5. #5
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Thank you for the reply.
    Annotative works great for everyone in office except for me. However I am the only one who has AutoCAD 2018. I'm beginning to think that may be the reason. I need to use annotative as this is an office template.
    So yesterday I spent a bit of time going through a list of commands to see if there is anything I can do. As there is not much I can do with the text styles as that is set the way it is. Apparently this is the first time that this kind of problem has occurred in their 6 years of practice. I actually think it has to do with the version of AutoCAD I have. As mine is the only one that is AutoCAD LT 2018. I also tried changing the scale as well. The problem is even worse than that as I hadn't really shown what happens during PUBLISH.
    So what I found worked best was
    1 - When opening an older file, back save to AutoCAD 2013 to avoid the big font problem all together.
    2 - Command BATTMAN can be used to sync all the attributes to their blocks again.
    However both 1 & 2 are visually only. As when I publish, the font is big again for some reason. However, this doesn't happen when I print to PDF. I looked through a couple thread and it seems like this is actually a common problem. I can get around it because this office doesn't have too many sheets to publish at once (MAX of 15 sheets). I can print them individually. I've attached a video of my work around.
    https://youtu.be/m5gZ8WbxaQw
  6. #6
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    AutoCAD LT 2018* I can't seem to find the EDIT post button. Sorry for consecutive replies!
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    Have you contacted Autodesk about this?
  8. #8
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Do you mean the AutoDesk Community Forum? If so, then yes.
    https://forums.autodesk.com/t5/autoc...ighlight/false
  9. #9
    Senior Member Squirltech's Avatar
    Squirltech's Computer Details
    Windows 7 Enterprise, Service Pack 1
    BOXX
    32.0 GB
    230 GB
    Single DELL 34" Curved
    Surveying
    Squirltech's Discipline Details
    Project Coordinator
    Surveying
    Civil 3D 2013
    Oct 2010
    30 15' N, 97 44' W
    272
    Just a thought...
    Is there a scale issue with the style being used? A multiplier maybe? Idk, just spit balling.
    T. Nelson - Project Coordinator
    http://www.sam.biz/
    "The only thing left to do is EVERYTHING!" - Jesse James
    "Work smarter, not harder" - Unknown
  10. #10
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Quote Originally Posted by SLW210 View Post
    If you mean the AutoDesk Community Forum, then yes I have. Here is the link. https://forums.autodesk.com/t5/autoc...ighlight/false
    Quote Originally Posted by Squirltech View Post
    Just a thought...
    I tried looking for that the first thing. There isn't one. If there was one, it should affect other people too. Since it's not, it's a contained problem with my AutoCAD only.
  1. using font size 0.01 = error
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2013, 07:01 pm
  2. Autocad 2012 Annotation Scale Arrow Gone ?
    By fpanjsh4 in forum AutoCAD General
    Last Post: 2nd Nov 2011, 03:33 pm
  3. AUTOCAD 2012 annotation scale arrow gone ?
    By fpanjsh4 in forum Student Project Questions
    Last Post: 2nd Nov 2011, 02:44 pm
  4. Access Annotation Plot Scale in AutoCAD MEP 2010 Using Lisp
    By xspacex in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Nov 2009, 08:40 am
