Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,954
    No, I mean to contact Autodesk to see if they can determine if this is a bug, they may want to know and fix it. http://usa.autodesk.com/adsk/servlet...112&id=1073074
    If you are on Subscription your CAD Manager can post a report through the Subscription Portal, at least it used to be that way.
    Maybe an Autodesk employee will see your thread over there.
  2. #12
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Quote Originally Posted by SLW210 View Post
    I am not, but my boss is. I don't think he understands the problems I'm having with the software though...
  3. #13
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,954
    Have your boss give you access to the portal so you can explain everything to Autodesk yourself.
  4. #14
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    637
    Shanni are you using a template that's on your company's network?
  5. #15
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    I will try and do that. I'm quite new here and don't really wanna cause trouble. There are work around to this problem but it makes doing everything 10x more annoying. ;__;
    Quote Originally Posted by Ski_Me
    Yes I am.
  6. #16
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    You could do an equivalent to a PUBLISH even with LT, if your layouts are consistent named D01 D02 Layout1 Layout2. I would use excel to write the command line sequence for Plot, we have this for our plotting via a menu just pick an option and it happens correct plot output via lisp. To see what I mean type -plot and answer the questions hopefully its supported in LT. This would save setting a Publish for every dwg but it does rely on some rules like Title block in a layout and always at 0,0.
    Dana W -plot ?
    Code:
     command version
    CTAB Layout1
    -PLOT
    Y
    CutePDF Writer
    A3
    m
    LANDSCAPE
    N
    W
    -6,-6
    807,560
    1=2
    C
    Y
    DesignLaserCOLOUR_1.ctb
    Y
    N
    N
    N
    N
    pdfname
    N
    y
  7. #17
    Super Member
    Electrical
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    637
    Ok so I thought you were having issues with your template because I noticed on one of your videos that a reference was missing when you opened the file. Now that I looked at this closer I see where your selecting blocks and the text looks like attributes. Could it be that every time you open the file the block is somehow exploded? If you insert a block from a different location then you get a dialog box that has a check box asking you if you want to insert the block exploded. And if you just copy and paste the block instead of inserting it then you will have the same issue with every copy of that block. What I'm saying is that the block was inserted exploded then copied and pasted using the copy command then the attributes were edited for each location. Have you tried inserting the block again from the same location?
  8. #18
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Quote Originally Posted by BIGAL View Post
    Dana W -plot ?
    Code:
     command version
    CTAB Layout1
    -PLOT
    Y
    CutePDF Writer
    A3
    m
    LANDSCAPE
    N
    W
    -6,-6
    807,560
    1=2
    C
    Y
    Y
    N
    N
    N
    N
    pdfname
    N
    y
    Hmmm I tried this and it brought out the same result. Since I don't have CutePDF Writer, I just used dwg to pdf output. *shakehead*
  9. #19
    Forum Newbie
    Architectural
    AutoCAD 2018
    May 2017
    9
    Quote Originally Posted by Ski_Me View Post
    I'm not exactly sure what you mean. XD The missing reference is because the template moves from computer to computer. The texts are attributes attached to a block. The block isn't exploded when I open it because I am still able to change all the options. It goes back to the normal size through some forceful refresh (similar to regen). I'm not sure where the block is located. I tried remaking the block, but I am not sure how it was made. I can't, for the life of me, seem to get annotation scale to work on the new block (and the annotations on the old one is whack). ;__; *dead inside* Not sure if I can solve this problem. I've been trying to fix it for 2 weeks already.
  10. #20
    Super Member
    Electrical
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    637
    Ok have you tried to delete the annotative of the block and replace with your scale? You can have more than 1 scale for each annotative block. Right click on the block and then select the annotative scale in the menu. You have to do this in block editor because your text might have scales imbedded in the block. Now that you mention annotative scales are in use this is making more sense.
  1. using font size 0.01 = error
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Feb 2013, 07:01 pm
  2. Autocad 2012 Annotation Scale Arrow Gone ?
    By fpanjsh4 in forum AutoCAD General
    Last Post: 2nd Nov 2011, 03:33 pm
  3. AUTOCAD 2012 annotation scale arrow gone ?
    By fpanjsh4 in forum Student Project Questions
    Last Post: 2nd Nov 2011, 02:44 pm
  4. Access Annotation Plot Scale in AutoCAD MEP 2010 Using Lisp
    By xspacex in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Nov 2009, 08:40 am
