Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Forum Newbie
    Construction
    AutoCAD 2016
    May 2017
    7
    Default I imported a drawing that is not 1:1 scale , when I draw in it, the units are wrong!
    Hi,
    So I downloaded a 2D plan of a fastener from McMaster-Carr. I copied and imported it in a new drawing (to see the difference). I want to use it to make a simplified representation and an assembly drawing. However, the drawing does not seem to be at a 1:1 scale. I can't figure out how to know what scale it is on the use the scale command to factor it. Is there a way I can convert it to a 1:1 scale?
    If i change the dimscale/style it changes but, the drawing is still off.
    I attached a screenshot of what I mean. The length is supposed to be 3'' but when I measure it it's actually 4.5''. The length is supposed to be 3'". I want to draw in the same scale as the drawing.
    Thank you for your time, if I'm not clear please tell me, it's my first post.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Yes, it happens occasionally with their files.
    Use the Scale>Reference option.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Is the 4.5 the only dimension that is wrong? Can you upload the drawing so we can examine it?
    If one or more of the other dimensions are correct, it could be that the bolt is simply drawn incorrectly.
    EDIT: Also, SLW might have nailed it. I have seen some of their drawings with a few of the dimensions overridden. Somebody doesn't see the point of changing the geometry to match only one dimension. If I had to draw a few dozen bolts which only vary in length I could see why.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor xoHaya.
    If the only dimension which appears wrong, because it was overridden, as Dana suggests, is the length, then easily fixed.
    Turn on your ORTHO.
    Copy your bolt up a known distance, let's arbitrarily say 4 inches.
    Offset the line which represents the flat underside of the bolt head, to the right by 1 1/2".
    Use the TRIM command with ALL option, and ERASE, to quickly remove any of the unwanted threaded shaft, which is obviously defined by the area between the bottom surface of the bolt head and the offset line.
    Then move the remaining threaded shaft, which now measures 3", to the left by 1 1/2".
    You can then move the original bolt and the new trimmed bolt by 4", to incorporate your new linework.
    Call it a day.
    You may want to save it as a block, with the WBLOCK command, which will make it easier to copy or move around, once you have it how you want it.
    May all your problems, be so quickly and easily resolved.
  5. #5
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    I went and got that file from McMaster-Carr and mine is properly scaled.
    Can you upload the .dwg you got from McMaster-Carr?
  6. #6
    Forum Newbie
    Construction
    AutoCAD 2016
    May 2017
    7
    Default Here is an example
    Thank you all for your answers!
    Here is my file to show what i mean. The dimensions I took are in red. Half the dimensions are good.. the other half are off.
    So I just have to modify the drawing, it has nothing to do with the scale?
    McMaster Prob.dwg
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    They aren't off. Maybe it's the fact you have the precision for dimensions set to two decimal places and not three.
  8. #8
    Forum Newbie
    Construction
    AutoCAD 2016
    May 2017
    7
    Oups! you are right! sorry! let me get the file I was working with yesterday!
  9. #9
    Forum Newbie
    Construction
    AutoCAD 2016
    May 2017
    7
    PROB.dwg
    Here we are. So if i draw a line of 3", it makes a line of 2" ?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Who was it that applied a measurement scale factor, in the dimensions style dialog box, of 0.666666666667? Was it you?
    I think someone scaled the parts up (1.5004444X) then to get the correct dimensions they changed the measurement scale factor to the value previously mentioned. Who did it or why is a mystery to me.
  1. set the units of imported xref to be equal to the host drawing's units
    By samifox in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jan 2016, 11:27 pm
  2. Wrong Scale, Wrong Units IDK???
    By snakeyes in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Dec 2014, 03:55 pm
  3. wrong drawing units
    By rosswhiteeca in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Nov 2014, 05:14 pm
  4. Wrong scale on my Xref drawing
    By mightythor in forum AutoCAD Beginners' Area
    Last Post: 4th Aug 2011, 07:56 pm
  5. Replies: 8
    Last Post: 30th Nov 2010, 07:54 am
