bababarghi Posted May 3, 2017 Share Posted May 3, 2017 Hi all, I have an Excel sheet containing hyperlinks to some *.dwg files stored somewhere on a network drive (each CELL in Excel document has been hyperlinked to a *.dwg file). The annoying thing is, whenever I click on a hyperlink in my Excel sheet, the correspondant *.dwg file gets opened in current AutoCAD session BUT the AutoCAD's window gets restored from its MAXIMISED size and I have to manually click and maximise the window again. I am using Office 2010 with AutoCAD v2018. Can anyone help solving this issue please? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 3, 2017 Share Posted May 3, 2017 (edited) It sounds like you might have the AUTOCAD properties set to run in NORMAL window size. Might you prefer to have it set to MAXIMIZED. Edited May 3, 2017 by Dadgad Quote Link to comment Share on other sites More sharing options...
bababarghi Posted May 3, 2017 Author Share Posted May 3, 2017 Thanks for the reply but I am afraid that was not the case. I set it as you mentioned but it still does the same thnig :/ Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 4, 2017 Share Posted May 4, 2017 You're welcome, it was worth a shot, sorry it didn't fix your problem. Quote Link to comment Share on other sites More sharing options...
