Results 1 to 6 of 6
    Forum Newbie
    Construction
    AutoCAD 2014
    Apr 2017
    5
    Default vba macro to move all red elements in the drawing to one layer
    Hi All,
    In the drawing, there are a lot of element in diffrent colors and all are in layer 0.
    How do I do a vba macro to move all red elements in the drawing to one layer, for example to an existing layer named red?
    I need a vba macro which not require any manual input, that dialouge boxes open for user select, etc...
    Junior Member spiff88's Avatar
    spiff88's Computer Details
    Windows 7 SP1
    Dell Precision T3600
    Intel Xeon E5-1650 @ 3.2 GHz
    16 GB
    NVIDIA Quadro 600
    600 MB
    2 GB
    dual 1920x1080
    AutoCAD 2015
    Oct 2008
    Portland, OR
    10
    This VBA code will work from within Excel VBE as long as you set the References to the AutoCAD 20xx Type Library for your version of AutoCAD.
    To use, open the DWG, then run the code in the Excel VBE. The code loops through all objects in model spaces, the IF-THEN checks the color, and then changes the layer if the color = 1 (red).
    Code:
    Sub MoveRedObjects()
    Dim objApp As AcadApplication
    Dim objDoc As AcadDocument
    Set objApp = GetObject(, "AutoCAD.Application")
    Set objDoc = objApp.ActiveDocument
        For Each obj In objDoc.ModelSpace
            If obj.Color = 1 Then
                obj.Layer = "red"
            End If
        Next
    End Sub
    Hopefully this does what you need.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,015
    spiff88 probably a good idea to make the new layer Red_layer_name before doing object collection so no crash on layer does not exist.
    Johanlang an extra question do you have blocks that are all red ?
    Full Member
    AutoCAD 2010
    Oct 2013
    78
    You could narrow down selectionset to filter elements whose color is Red only
    Code:
    Sub MoveRedObjects2()
        Dim redsSset As AcadSelectionSet
        Dim acEnt As AcadEntity
        If GetColoredEntities(redsSset, 1) Then
            ThisDrawing.Layers.Add ("Red")
            For Each acEnt in entsSet
                acEnt.Layer = "Red"
            Next
        End If
    End Sub
    Function GetColoredEntities(redsSset As AcadSelectionSet, color As Integer)
        Dim gpCode(0 to 0) As Integer
        Dim dataValue(0 to 0) As Variant
        gpCode(0) = 62: dataValue(0) = 1 'red color
        On Error Resume Next
        Set redsSset = ThisDrawing.SelectionSets.Add("Reds")
        On Error GoTo 0
        If redsSset Is Nothing Then Set redsSset = ThisDrawing.SelectionSets.Item("Reds")
        With redsSset
            .Clear
            .Select acSelectionSetAll, , , gpCode, dataValue
            GetColoredEntities = .Count > 0
        End With
    End Function
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,015
    I would do like above posters make a little sub to check colour layer actually exists, then only difference is I would just make the layer name the colour number and then at end change the layer names to something meaningfull. This way just keep going until end of drawing, if you have rgb colours then layer could be R-G-B 123-100-200
  6. #6
    Full Member
    AutoCAD 2010
    Oct 2013
    78
    With
    Code:
    It adds the wanted layer if not already there or it does nothing (not even throws any error) if it exists already
  1. Change layer of Block Elements
    By hosannabizarre in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2014, 08:37 am
  2. Offsetting drawing elements to a different layer
    By martyn60 in forum Mechanical & MDT
    Last Post: 20th Oct 2010, 03:07 pm
  3. Applying layer changes to existing elements
    By ihavenolife in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2008, 04:38 pm
  4. change an elements layer
    By studiorat in forum AutoCAD General
    Last Post: 3rd Jan 2008, 05:57 pm
  5. Macro to remove all layer filters and purge a drawing
    By corradophil in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jun 2006, 04:11 pm
