Kagap Posted May 4, 2017 Share Posted May 4, 2017 Hello all, I'm brand new and so if this question is somewhere else, or this is not the correct thread, I apologize in advance. While using AutoCAD 2015, I've noticed the past couple of days that the WCS Navigator gets sort of stuck. By that, I mean that it's acting like an object instead of something that stays in the upper right corner of my window. I've attached a couple screenshots here to help illustrate. Both attachments show the problem I'm having. The first attachment "Normal WCS" shows it as normal, however the second attachment shows what it looks like when I zoom in to it. It's not stationary at all. Has anyone else had this issue? How do I go about fixing it? Thanks for your help! Quote Link to comment Share on other sites More sharing options...
halam Posted May 4, 2017 Share Posted May 4, 2017 I' Having troubles with it in the way that it sometimes fails to display. Even with the right setvars. Switching 2d / 3d. Shut down autocad, restart, ... Get some coffee,.. Wait till its cold.. and back to work.. Buggy Autocad Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted May 4, 2017 Share Posted May 4, 2017 My solution is both elegant and instructive. Turn the darn thing off. It's no different than a pop-up in a browser window, it can intercept a click you intended for your work surface. There are several other ways to do the things it does, you're better off finding one that works for you. Quote Link to comment Share on other sites More sharing options...
Kagap Posted May 4, 2017 Author Share Posted May 4, 2017 Hmm. I agree that your solution is indeed elegant and instructive. That's the very first thing I tried. It seems to sort of revert back to being a non-stationary tool. I'm clearly missing something while I'm working, but I'll keep an eye out. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
