Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Would it be possible to make a similar command to the ADD command that will put in a comma for the answer? Maybe call it AddC.
  2. #12
    Senior Member
    not applicable
    Oct 2014
    159
    There's a nice piece of code written by John Uhden over on the Autodesk Community Forums that puts commas into strings. I've integrated his code into the ADD program here. Give it a try:
    Code:
    ;AddC.lsp 6/17/96
    ;v1.01 7/2/96 fixed to use local variables
    ;v1.02 1/15/97 Cleaned up commented out code. Added more instructions.
    ;v1.03 10/3/06 revised the program to work with numbers that include commas.
    ;v1.04 11/20/06 revised the program to stop adding zeros on the end.
    ;Add string lisp routine will take a selection of text and add the
    ;numbers together.
    ;Use:
    ;Select some stuff. All non-text items are ignored. Any numbers in
    ;the selected text will be added together. Select a text item to be
    ;updated. The selected text item will be replaced with the result of
    ;the addition.
    ;Note that the units command will affect the format of the results.
    ;If you get a number will a bunch of trailing 0's then change units
    ;to fix the problem.
    ; below is the subroutine that removes the commas from the numbers and changes decimal points
    ; added by me
    (princ "\nEnter \"addc\" To Start Program.")
    (defun comma ( / nc nt m tmp ntext )
      (setq nc 0)                   ;set counter to 0
      (setq m T)                    ;set m to true
      (setq ntext "")               ;blank out ntext
      (setq nt (strlen text1))      ;initalize counter (text1 from calling program)
      ; while loop test for ascii decimal point or number between 0 and 9 and eliminates none decimal or number char.
      (while m
        (setq nc (+ nc 1))
        (setq tmp (ascii (substr text1 nc 1)))
        (if (or (= tmp 46) (and (>= tmp 48) (<= tmp 57)))
          (setq ntext (strcat ntext (substr text1 nc 1)))
        (if (= tmp 46)          ;this will adjust the decimal point to 1 if a decimal is present in the number.
          (setvar "luprec" 1)
      (setq nt (- nt 1))
      (if (= nt 0) (setq m F))
    (setq text1 ntext)
    ntext
    ;below is the original program
    ;end of by me
    ;dxf function takes an integer dxf code & ent data list and
    ;returns the value for that dxf code.
    (defun dxf (code elist)
       (cdr (assoc code elist))
    );defun
    ;ss1   - selection set
    ;n     - number of items in selection set (counter)
    ;total - total of float numbers in selection set
    ;e     -
    ;au    - current unit precision
    (defun C:addc ( / lu ed en et i n num ss1 text1 total # p#)
      ;added by me to remove the trailing zeros
      (setq lu (getvar "luprec")) ; save current precision
      (setvar "luprec" 0) ; set precision to 0
       (setq ss1 (ssget '((0 . "TEXT"))))     ; Select objects, only text
       (if ss1                        ; If any objects selected
             (setq i 0
                   total 0
                   n (sslength ss1)); reset tot, set n to number of items
             (while (< i n)             ; For each selected object...
                (setq text1 (cdr (assoc 1 (setq e (entget (ssname ss1 i))))))
                ;below is the subroutine call to remove the commas
                (comma)
                (setq total (+ total (atof text1)))
                (setq i (1+ i))          ; increment counter
             );while
          );progn
       );if
       (princ "Total ")
       (princ total)
       (terpri)
       (setq en (entsel "\nSelect text to update to total")
             ed  (entget (car en))
             et  (dxf 0 ed)
       (if (= et "TEXT") ; verify text was selected
    ;(rtos total 2) returns total formated as a string in decimal format
    ;substitute the new text for the old text...
    ; RTOC Comma code by: John Uhden (Autodesk Community Forums)
           (setq num total)
           (setq # 1)
           (setq num (rtos num 2 #) # 1)
             (while (and (/= (substr num # 1) ".")(<= # (strlen num)))
               (setq # (1+ #))
           (setq # (1- #) p# #)
             (if (= (setq # (rem # 3)) 0)(setq # 3))
             (while (< # p#)
               (setq num (strcat (substr num 1 #) "," (substr num (1+ #)))
                     # (+ 4 #)
                     p# (1+ p#)
           (entmod (setq ed (subst (cons 1 num) (assoc 1 ed) ed)))
       );if
     (setvar "luprec" lu) ;return precision to it's original value
    );defun
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Thanks! How do I get it to do that without the decimal point?
  4. #14
    Senior Member
    not applicable
    Oct 2014
    159
    Quote Originally Posted by ryankevin15 View Post
    Change the "1" to a "0" here:
    Code:
           (setq num total)
           (setq # 0)
               (setq # (1+ #))
             (while (< # p#)
                     # (+ 4 #)
                     p# (1+ p#)
    BricsCAD V15
  5. #15
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    So, this is the code to find 25% continuous lighting load. Could you help make it to where it will round to the nearest whole number and insert a comma?
    Code:
    (princ "\nEnter \"208\" To Start Program.")
      (while m
        (setq nc (+ nc 1))
          (setvar "luprec" 1)
      (setq nt (- nt 1))
    (setq text1 ntext)
    ntext
    ;end of by me
    );defun
    ;e     -
    (defun c:25 (/ en1 en2 ed1 ed2 et1 et2 watts amps ent text1)
    (while
      (not
        (and
          (setq
            en1 (entsel "\nSelect TOTAL LIGHTING LOAD: ")
            ed1 (if en1 (entget (car en1)))
            et1 (cdr (assoc 0 ed1))
          (= et1 "TEXT")
      (prompt "\n-- 0 items selected, or not TEXT --")
    (setq watts (cdr (assoc 1 ed1))
          text1 watts
    (comma)
    (setq amps (rtos (/ (atof text1) 4) 2 1))
    (princ (strcat "\n25% LIGHTING LOAD = " watts))
    (while
      (not
        (and
          (setq
            en2 (entsel "\nSelect DEMAND AMPS: ")
            ed2 (if en2 (entget (car en2)))
            et2 (cdr (assoc 0 ed2))
          (= et2 "TEXT")
    (entmod (setq ed2 (subst (cons 1 amps) (assoc 1 ed2) ed2)))
    );defun
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Quote Originally Posted by SLW210 View Post
    Using Code Tags will remove the smiley faces.
    Fixed, finally understood what the problem was. haha.
  7. #17
    Senior Member
    not applicable
    Oct 2014
    159
    This should work. I added a function that rounds up at 0.5 or greater since you're dividing by 4.
    Code:
    (princ "\nEnter \"25\" To Start Program.")
      (while m
        (setq nc (+ nc 1))
          (setvar "luprec" 1)
      (setq nt (- nt 1))
    (setq text1 ntext)
    ntext
    ;end of by me
    );defun
    ;e     -
    (defun c:25 (/ en1 en2 ed1 ed2 et1 et2 num rndamps watts amps text1)
    (while
      (not
        (and
          (setq
          (= et1 "TEXT")
          text1 watts
    (comma)
    (setq amps (rtos (/ (atof text1) 4) 2 2))
    (while
      (not
        (and
          (setq
          (= et2 "TEXT")
    (setq amps (/ (atof text1) 4))
    (if (< (- amps (fix amps)) 0.5)(setq rndamps (fix amps))(setq rndamps (1+ (fix amps)))) ;Rounding
    (setq rndamps (rtos rndamps 2 0))
       (if (= et2 "TEXT")
    ; Changing the "#" from 1 to 0 removes the decimal place.
           (setq # 1)
           (setq num rndamps)
               (setq # (1+ #))
             (while (< # p#)
                     # (+ 4 #)
                     p# (1+ p#)
    (entmod (setq ed2 (subst (cons 1 num) (assoc 1 ed2) ed2)))
    );defun
    BricsCAD V15
  8. #18
    Full Member
    Electrical
    AutoCAD 2016
    Apr 2017
    74
    Using these all on a daily basis. Thanks!!
  9. #19
    Senior Member
    not applicable
    Oct 2014
    159
    Good to hear! Glad to have been of help.
    BricsCAD V15
  1. Electrical Homerun Lisp
    By caditnow in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Sep 2015, 02:11 am
  2. Useful lisp for electrical engineers
    By hosyn in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2013, 01:40 pm
  3. Tips for improving workflow.
    By spittle in forum SolidWorks
    Last Post: 15th Jan 2009, 04:37 pm
  4. Improving my cad skills
    By Faceless Master in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2006, 10:51 am
Tags for this Thread
