Results 1 to 7 of 7
    Full Member
    AutoCAD 2016
    Jul 2008
    63
    Default Reference file control panel
    Is there one in autocad 2016? I just want to switch reference file on and off to see which ones I need to keep. Microstation had this excellent feature at least as far back as 1994. Has autocad caught up yet?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,564
    Are you talking about the Reference Manager palette?
    Or the external reference manager?
    Both have been there for 15+ years.
    You can also select the Xref, and then right-click and make your desired changes there.
    R.K. McSwain
    CAD Panacea | twitter
    Full Member
    AutoCAD 2016
    Jul 2008
    63
    Default Not Sure
    In microstation there is a feature that allows you to pull in a file to be used as a background. The file is referenced in but does not add to the size of the drawing since it is a separate file. I thought AutoCAD had a similar feature.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Quote Originally Posted by bustr View Post
    That is the way xrefs work in AutoCad, unless you Bind them to the dwg file, only the image of the xref is in the drawing, not the file data.
    To turn them on and off, you simply open the xref manager, in one of two ways.
    1. Click on an xref and then click on the External References tile on the contextual ribbon tab that comes up, or
    2. type XREF. Then select your desired xref file name, right click. Then click Unload to turn that reference off, and Reload to turn it on. Easy Peasy Lemon Squeezy.
    OR, you can select an xref image, open Properties, and toggle SHOW UNDERLAY to No, or Yes. Even easier. and faster. Note that this one does not unload the xref image.
    Neither method changes or moves the xref in any way, but UNLOAD makes it unselectable. reload puts it back in the same place. SHOW > No, leaves the reference image selectable but invisible.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,564
    Yes, what you are describing is called an External Reference, or XREF for short, in AutoCAD. This has been around since 1990.
    R.K. McSwain
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Have you caught up yet?
    Drafting is a breeze.
  7. #7
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    814
    Microstation has added support for layer names, TTF fonts, xrefs and enough to put it where AutoCAD Light was a quarter century ago. Still no support for lisp like most CAD software.
  1. One reference file to control multiple reference layer settings
    By Sam Pawar in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jul 2012, 02:38 pm
  2. The ribbon - new panel display control
    By jules_s in forum AutoCAD Beginners' Area
    Last Post: 26th Apr 2012, 11:58 pm
  3. no control panel for my posts!
    By gib65 in forum Feedback
    Last Post: 17th Jan 2008, 08:18 pm
Tags for this Thread
