Results 1 to 4 of 4
    Forum Newbie
    Construction
    AutoCAD 2017
    Jan 2017
    4
    Unhappy Stretch Then Zoom
    Hi,
    Experienced user. 8 yrs +.
    Issue is with AutoCAD 16 and the stretch command. If im in the stretch command dragged top right to bottom left and then zoom in or out the command doesn't work correctly and my points will not stretch.
    Hasn't always been like this on previous versions.
    please help its driving me nuts!!
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Is it just one drawing, some drawings or all drawings?
    Does it work if you don't zoom?
    What objects are you trying to stretch?
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,211
    I've seen this before. If you select some objects and then zoom in, the objects not visible can get dropped from the selection set. I could never get it to happen consistently, so I worked around it.
    See also this thread: http://www.cadtutor.net/forum/archiv.../t-69545.html?. There's some discussion over whether or not this is a bug. If I select a group of objects, and some of them get unselected without my input, I'm going to call that a bug.
    If that's not your problem, we'll need more information.
    Edit: A workaround I just learned about, use WPolygon and CPolygon to control the selection process. They won't work for every situation, but they might get you out of a jam.
    breaking AutoCAD on a regular basis since 1991
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    It's "fixed" as of 2017.1.
    Drafting is a breeze.
  1. Polar Stretch and Linear Stretch don't work together?
    By Asterisk in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2011, 06:35 am
  2. zoom extends doesn't zoom completely (hidden objects issue)
    By khoshravan in forum AutoCAD General
    Last Post: 4th Jul 2011, 06:21 am
  3. Stretch Wont Stretch
    By daveyboyd in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Dec 2009, 02:59 am
  4. Strange bug: Scroll mouse zoom out or ZOOM OUT
    By Martin Carmona in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 11:42 pm
