Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    Default add + operator to a formula that use field
    hi
    using acad 2017,
    i use fields with object's Y position to read the current level.usualy is a relative level that start with 0.00
    now i want to do the same but with absolute level,
    for example , moving the level symbol and the associated text shows +0.10, i want autocad to add 290.10 to +0.10 reading so the total reading displays + 290.20
    not sure how to do it?
    Thanks in advance
    S
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    When you are in the field dialogue, choose formula from the field names section, and in the formula entry box you can place your constant and use right click to enter another field (object). You can add or choose multiple fields within the formula, or diesel expressions so you can also access stored variables.
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    Thanks a lot Steven
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    hi
    using formula like 290.10+(-209.57/100) to show an absolute level works great till the designer called to ask to set the 0.00 to 286.60 instead of 290.10.
    now i had created millions of copies to that field, that mean that i have to go 1 by 1 and to change them, manually?
    how can i set a variable to hold my absolute value and still be able to use that formula?
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    You can use a diesel expression in one (or more) of the fields you use in the formula, and then all you need do is change the variable value with the setenv command, and it will update on regen, you might need to alter the Fieldeval variable fieldeval=31 to get the fields to update nicely.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  6. #6
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    Quote Originally Posted by steven-g View Post
    Attachment 61716
    didnt tried it yet but you are the king !!!! thanks
  7. #7
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    i test it, its great, i close and open cad so its saved with the drawing or with the Operation system? what happened when i open the same drawing in other pc?
    setenv is an Autolisp function? getend is diesel ....how they interact?
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    It sounds like it would be easier using normal text that is calculated of a base point then use something like our "add to levels lsp" to adjust all the required text.
  9. #9
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    seems like the setenv store the value along with the drawing. is this the case?
  10. #10
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    Nope setenv is just a command to set an environmental variable and it is stored in the Windows registry, so it is not saved with the drawing it is the same value for all drawings. Looking a bit more it appears as though the setenv and getenv are unique to LT as command line functions (yeah one up for the LT guys), though it is available to full Autocad through Lisp and probably Diesel. You'll have to test that yourself, aren't there any easy accessible variables in full Autocad?
    Another method would be to create a custom DWGPROPS value and this also becomes available in the field selection list (and is stored with the drawing)
  1. Formula field IF statement
    By Amail in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Feb 2016, 09:01 pm
  2. AutoCAD Formula Field Plot issue
    By Shoey in forum AutoCAD General
    Last Post: 23rd Nov 2015, 06:37 pm
  3. Create a leader with a formula & field within via vba
    By dan_g8 in forum .NET, ObjectARX & VBA
    Last Post: 27th Oct 2014, 01:53 pm
  4. Problem with Formula Field in Dynamic Block
    By robwalker24 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Sep 2010, 02:44 pm
  5. Decimal places in Formula Field in a Table
    By dabatman in forum AutoCAD Drawing Management & Output
    Last Post: 6th Feb 2008, 05:45 am
