Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Super Member
    AutoCAD 2010
    Dec 2010
    1,246
    it seems like the drawing hold the value, i have restarted the pc and its still there
  2. #12
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,800
    What about a single text on a non plot layer change it, values change.
  3. #13
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,174
    +1 BIGAL
    I would have thought it would read it in as text and fail, but it works in the formula field just fine both text and mtext.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  4. #14
    Super Member
    AutoCAD 2010
    Dec 2010
    1,246
    Quote Originally Posted by steven-g View Post
    Nope setenv is just a command to set an environmental variable and it is stored in the Windows registry, so it is not saved with the drawing it is the same value for all drawings. Looking a bit more it appears as though the setenv and getenv are unique to LT as command line functions (yeah one up for the LT guys), though it is available to full Autocad through Lisp and probably Diesel. You'll have to test that yourself, aren't there any easy accessible variables in full Autocad?
    Another method would be to create a custom DWGPROPS value and this also becomes available in the field selection list (and is stored with the drawing)
    hi steven
    yaa set it a costume property as ABS and than get it in the field works better, now i can be sure its saved with the drawing
  1. Formula field IF statement
    By Amail in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Feb 2016, 09:01 pm
  2. AutoCAD Formula Field Plot issue
    By Shoey in forum AutoCAD General
    Last Post: 23rd Nov 2015, 06:37 pm
  3. Create a leader with a formula & field within via vba
    By dan_g8 in forum .NET, ObjectARX & VBA
    Last Post: 27th Oct 2014, 01:53 pm
  4. Problem with Formula Field in Dynamic Block
    By robwalker24 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Sep 2010, 02:44 pm
