+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Full Member
    Using
    AutoCAD 2005
    Join Date
    Feb 2011
    Posts
    35
    Angry Locking toolbars
    Hello:
    I am using AutoCAD 2006. I have arranged my toolbars in the position that I wanted them. I went and "locked" all toolbars after that thinking this would hold their position. I then saved my drawing and closed the drawing. When I came back and reopened my drawing later, the toolbars had moved to a different location. Why won't they stay where I put them if I "locked" them ?? What is going on !!
    Seems like a simple thing, but this is crazy..
    Kim
  2. #2
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    5,995
    Default
    It sounds like you failed to NAME & SAVE the workspace, which includes the locked locations of the toolbars.
    Beware that in the Workspace settings, there is an option to automatically save workspace changes, or not.
    You can also set your Default workspace.
    But, you definitely should name and save your workspace.
    I have a few different ones saved, which I use for different tasks, which I have named accordingly.
    https://knowledge.autodesk.com/suppo...C2404-htm.html
    Not sure how much of that link will pertain to your situation, as you are using Autocad 2006, but probably still a good overview.
    Volume and repetition do not validate opinions forged in the absence of thought.
Similar Threads
  1. Locking UCS
    By elfert in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Feb 2012, 06:29 pm
  2. Locking An .IDW
    By vertical horizons in forum Autodesk Inventor
    Last Post: 2nd Sep 2010, 08:35 pm
  3. Locking VP
    By sw987 in forum AutoCAD General
    Last Post: 15th Dec 2008, 10:18 pm
  4. Locking Viewports...
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2006, 04:28 pm
  5. Locking toolbars in place CAD 2004
    By Volred in forum AutoCAD Drawing Management & Output
    Last Post: 21st Nov 2005, 11:43 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
