Results 1 to 6 of 6
    Junior Member
    Multi-disciplinary
    AutoCAD 2016
    May 2017
    10
    Default Find and Replace
    Here is my issue, in the drawing I have Note ("x"), I need it to read (Note "x")
    "x" has many different numbers.
    I can use the find to get Note (*) but I don't know how to replace it with the same number. it puts in (Note ("*").. It actually puts in the asterisk and not the original number.
    Can someone help me with this..
    Thanks
    Senior Member
    not applicable
    Oct 2014
    159
    Can't you just replace the beginning characters instead? In the example below the underscore is to show a blank space:
    Find: Note_(
    Replace: (Note_
    BricsCAD V15
    Junior Member
    Multi-disciplinary
    AutoCAD 2016
    May 2017
    10
    Yes, but I have a lot of different variations of this i.e. Note (2), or Note (5), or Note (2)(3)(4)... And this needs to change to (Note 2), or (Note 5) or (Notes 2,3,4)...
    And this needs to happen across many drawings... I could write a routine to fix this, but since I have to go into all drawings anyway, I was just going to use the "Find and Replace" command..
    Senior Member
    not applicable
    Oct 2014
    159
    Ah. Thought that was too easy. With that many variables I don't see an easy way, but someone else might... good luck!
    BricsCAD V15
  5. #5
    Junior Member
    Multi-disciplinary
    AutoCAD 2016
    May 2017
    10
    Thanks for trying though...
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor nick.
    You might want to check out this gem from Lee Mac
    http://www.lee-mac.com/bfind.html
    Thanks Lee!
    This is an outstanding lisp, which may or may not help you this time, but one to keep handy, as it certainly will come in handy at some point.
    One huge advantage to using Lee's lisp, is that you don't even need to OPEN any of the drawings, it is automagic!
    It even generates a report of everything it finds and changes, which is a helpful overview, for quick inspection without opening all the drawings to look at them.
  1. How to find * and replace with X
    By shailujp in forum AutoCAD General
    Last Post: 25th Mar 2014, 03:08 am
  2. find and replace
    By anilanand in forum AutoCAD General
    Last Post: 19th Oct 2012, 07:13 am
  3. find&replace
    Last Post: 19th Jul 2012, 12:34 pm
  4. Replies: 6
    Last Post: 13th Jul 2011, 02:19 pm
  5. Find and Replace
    By gil9166 in forum AutoCAD General
    Last Post: 2nd Aug 2009, 10:37 pm
