Results 1 to 8 of 8
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Default Mass element hatch in 2D-Wireframe TOP view
    Hello,
    How can I view the hatch of the material when it is assigned to a Mass Element?
    To be displayed on the 2D-Wireframe TOP view.
    This is not a cut plane view but TOP elevation view (above cut plane).
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    Can you post an example drawing?
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Hello SLW210,
    The situation is very simple:
    Create one mass element and assign bricks material to that mass element. That is all.
    If you select the "Realistic Visual Style" and set the View Point to "SW Isometric" (for example) you can see the bricks in 3D on that Mass Element. That obvious.
    NOW
    If you select the "2D Wireframe" and set the View Point to "Top" you see the top surface of the mass element but no 2D pattern is shown. I believe Autocad can display a certain pattern based on the assigned Material or certain display parameters of the Mass Element.
    Thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    "I believe Autocad can display a certain pattern based on the assigned Material or certain display parameters of the Mass Element."
    Could you be referring to a surface hatch component in a material definition?
    Where did you read this? "I believe Autocad can display a certain pattern based on the assigned Material or certain display parameters of the Mass Element." I would like to read up on this feature. Thanks.
  5. #5
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Autocad can display Mass Elements surface hatch when the mass element is displayed in isometric view (in 2D wireframe).
    Autocad can also display cut surface of a mass element when the mass element is of course displayed in TOP view (in 2D wireframe).
    SO I wonder if Autocad can display Mass Element surface hatch when 2D wireframe is displayed in TOP view.
    Regarding your question about hatch and Materials please see attached file.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    Since you didn't bother to answer either of my questions I guess I'll move on. Good luck solving your problem.
  7. #7
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    This would seem to be specific to AutoCAD Architecture, not plain AutoCAD.
    Thread moved to Architecture & ADT Forum.
  8. #8
    Senior Member
    Architecture 2013
    Dec 2009
    123
    I just found out a workaround solution for that issue. A solution that displays the Mass Element hatches in 2D Wireframe TOP view and hence it saves the need to add 2D hatch for each existing 3D Mass Element.
    The solution: I make each mass element to display with a cut plane.
    This is the simple cut plane display: In Display Property for the Mass Element:
    1. In Hatching tab, add proper hatch
    2. In Layer/Color/Linetype tab, turn on the Hatch
    3. In Other tab, turn on the Override Display Configuration Cut Plane and assign a Cut Plane that is lower than the Mass Element height
    I think that Autocad should enable to display the hatch also for the TOP view surface (not only the cut plane) - but this is not possible as I understand.
    I use these Mass Elements to display ground objects such as out door tiles and grass.
    I wonder if there is a better solution for that...
  1. Autocad 2011 Mass Element Issues
    By drunkmunky in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Jun 2012, 10:15 pm
  2. element borders in layout view
    By Yagoona in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2011, 12:00 am
  3. Replies: 16
    Last Post: 25th May 2011, 06:56 pm
  4. 3d solid v. mass element
    By Geoffers in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Apr 2011, 11:33 am
  5. Stretch mass element in dynamic block
    By ricsivahl in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Mar 2011, 12:16 am
