gabrielhii1995 Posted May 14, 2017 Share Posted May 14, 2017 I had tutorials before that mention the use of split lines in guiding proper meshing of solid parts in my subject Finite Element Analysis. For now, I know how to apply mesh and apply mesh control as well but when I got my assignment question and I quote : Construct a model for angle bracket in Solidworks and provide figure showing mesh, loads, and boundary conditions. Problem is, I not sure in such case whether do I need to draw split lines in my model before I apply meshing on it. Please help. Here's my model drawn and my assignment question: FEA_assignment(2).pdf And appreciate if someone can teach me how to do mesh sensitivity analysis given in the assignment question? Thanks. FEA assignment.SLDPRT Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 15, 2017 Share Posted May 15, 2017 I moved your thread to the Solidworks Forum. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 16, 2017 Share Posted May 16, 2017 If this is an assignment for a grade i can't help you out there. Right on the PDF you uploaded it says "this assignment must be completed by each student individually". I can maybe give you some general answers to your questions. Split faces - You only need to do this if you need to apply a force to a specific area. This usually happens when you have something like the head of a bolt and you need to apply a force under that smaller circle around that area on your bracket. There are other reasons but that is probably the most general. Mesh settings are a complicated topic. There are adaptive mesh settings that allow the mesh to change based on feature size. Your best starting point is the help file to get you to the point you can ask a specific question that is not directly on the assignment you have. http://help.solidworks.com/2016/English/SolidWorks/cworks/IDC_HELP_MESHSOLID.htm Quote Link to comment Share on other sites More sharing options...
