Results 1 to 4 of 4
    Junior Member
    AutoCAD 2010
    Sep 2006
    Far N. Dallas area
    15
    Default 2nd Floor wider than 1st floor?
    Hello - I'm a Revit newbie - I'm making a graphic of 5 flr building to be used by the controls folks to show air zones, etc. The 2nd floor is 3 ft wider than the first floor. What is the best way to deal with this? The outside elevation doesn't really matter, the finished product will only show a plan view of the walls and doors. Just slice it right below the start of the 2nd floor and push the exterior walls out? Will it cause problems if, say, the flr 1 exterior walls just go up to flr 2, but the stairs go up to flr 5?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    When you initiate the Wall tool, look for the modify bar. You can have wall heights connected to levels. Do this for level one so it doesn't extrude up into the level 2 floorplan.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Junior Member
    AutoCAD 2010
    Sep 2006
    Far N. Dallas area
    15
    Duh, I didn't even consider that. Thanks for your speedy reply and going to the trouble to post a pic! Go Stars!
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    Quote Originally Posted by RedDirt View Post
    Go Stars!
    Now that we've signed Ben Bishop, go Stars indeed... next year!!
    -TZ
  1. Flattening a .... somewhat large 3d hospital ground floor to a 2d floor plan
    By amylmc in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Oct 2012, 11:30 am
  2. Drawing second floor
    By igones in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2012, 04:38 pm
  3. 2nd Floor
    By Timber in forum AutoCAD Beginners' Area
    Last Post: 28th Nov 2009, 11:28 pm
  4. Floor Plans
    By AMB4311 in forum AutoCAD Beginners' Area
    Last Post: 2nd Mar 2008, 11:28 pm
  5. Attach top floor to bottom floor.
    By K-Ro0 in forum AutoCAD General
    Last Post: 2nd Dec 2007, 03:08 am
