Call function outside of command [LISP]
OMEGA-ThundeR
Hi,
i'm trying to create a piece of code with a messagebox that ask a question (yes/no) which in turn should set an value that i can use in the 'main' command.
(Defun FUNCTION (reply)
(SETQ reply (ACET-UI-MESSAGE	"Content of questionbox" "Title of questionbox"
				(+ Acet:YESNO Acet:ICONQuestion)
As far as my 'function' knowledge goes this usually is defined within a command. i.e.:
(Defun c:command ()
(defun FUNCTION ( / a)
  (do something)
(FUNCTION (and do something with that function))
But i kind of want to use the function in multiple commands that work in a similar way, but don't want to add the lines of code to every command.
So, how do i make the following work?
(Defun c:CallFunction1 ()
FUNCTION
(Defun c:CallFunction2 ()
FUNCTION
(Defun c:CallFunction3 ()
FUNCTION
Should look something like this.
All three command's now open the dialog with the YES/NO question...
So there is no variable for the three commands in this case.
(defun FUNCTION ( / )
(setq reply (ACET-UI-MESSAGE "Choose dude " "Russells Dialog" (+ Acet:YESNO Acet:ICONQuestion)))
;; Yes = 6, No = 7
(if (= reply 6)
		(ALERT "Yep")
		(ALERT "Nope")
(defun C:CallFunction1 ( / )
(FUNCTION)
(defun C:CallFunction2 ( / )
(FUNCTION)
(defun C:CallFunction3 ( / )
(FUNCTION)
To do something different for each command, it could look like this:
(defun TESTCOMMAND ( number / )
;; Yes = 6, No = 7
(if (= reply 6)
		(cond
			((= number 1)
				(princ "Voorwaarden voor CallFunction1")
			((= number 2)
				(princ "Voorwaarden voor CallFunction2")
			((= number 3)
				(princ "Voorwaarden voor CallFunction3")
		(princ "NO, annuleren.")
(TESTCOMMAND 1)
(TESTCOMMAND 2)
(TESTCOMMAND 3)
(TESTED AND WORKING)
Edited by Aftertouch
Gives errors in both cases and i can't find a way to fix them :(. Seems to be going wrong in the command parts
This is the code i tested and works perfect. :)
;; Yes = 6, No = 7
(if (= reply 6)
		(cond
			((= number 1)
			((= number 2)
			((= number 3)
(TESTCOMMAND 1)
(TESTCOMMAND 2)
(TESTCOMMAND 3)
IMO you should strive for a 'YesNo' function with this signature:
(YesNoDialog "Title" "message") => T/nil (return value T or nil)
