Results 1 to 2 of 2
    Forum Newbie
    Electrical
    AutoCAD 2017
    May 2017
    4
    Default STEP file into Revit
    What is the best way to get a STEP file into Revit.
    I've tried to import into AutoCAD (in a effort to export to a dwg, etc.) but AutoCAD will not open it either.
    Is there another Autodesk program I can use to import Step files?
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    683
    Use Automesher !
    Better results Autodesk can't do.
    Automesher application extends AutoCAD / BricsCAD / ZWCAD software with the functionality to import and export 3D file formats and convert 3D drawing entities. It supports many of 3D file extensions, including STL (Stereolithography), OFF (Object File Format), OBJ (Alias Wavefront Object), 3DS (3D-Studio File Format), IV (Inventor File), SAT (Standard ACIS Text), PLY (Stanford Polygon Format), VRML (Virtual Reality), 3DM (Rhinoceros 3D Model), SKP (Google SketchUp), DAE (Collada), STEP (STandardized Exchange of Product), IGES (Initial Graphics Exchange Specification), BREP (Boundary Representation) and allows to convert drawing meshes (polyface or polygon mesh) into 3D solid objects.
    • Import STEP, IGES, BREP, 3DS, OFF, STL, OBJ, PLY, 3DM, DAE and SKP file formats.
    • Export STEP, IGES, BREP, STL, OFF, OBJ, 3DS, IV, PLY, VRML, 3DM, DAE, SKP and SAT files.
    • Transform polygon mesh into polyface mesh entity type in both directions.
    • Convert faces, polygon mesh, polyface mesh to solid.
    • Turn 3D solid drawing entity into polyface or polygon mesh.
    • Support for polyface mesh, polygon mesh, solid, 3D faces, lines, arcs and circles with thickness.
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  1. Replies: 0
    Last Post: 22nd Nov 2010, 07:43 pm
  2. 2 Step Command Alias in PGP File
    By EVGA Buzzer in forum AutoCAD Beginners' Area
    Last Post: 3rd Aug 2010, 07:24 pm
  3. Create a part from a Step file
    By garycrampton in forum Autodesk Inventor
    Last Post: 2nd Sep 2009, 12:02 pm
  4. Step by step convert dwg to tiff file
    By mrsdrafter in forum AutoCAD General
    Last Post: 29th Nov 2007, 10:37 am
  5. Import STEP file from Inventor
    By boot in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jul 2007, 03:55 pm
