Block attributes
keiths
Help needed, i made a block for a Speed Limit road sign which inserted i can change to various speeds...
hope it make sense...
Keith
Without more information, it's hard to tell what your problem is. Your subject hints that you've tried to include an attribute in your block. Did you create an attribute? What is it doing or not doing? What are its properties? Is the block or the text annotative? The attribute may not appear if the scale doesn't match or if it's too far off.
Edited by CyberAngel
Steven your right a dynamic block, but why not just make the range of blocks. We have some True Type fonts and they have the advantage of just edit the single character and a new speed pops up.
