Results 1 to 8 of 8
    Junior Member
    Civil
    AutoCAD 2016
    May 2017
    12
    Default Import Pipes Name from Excel
    It is any way to Import Pipes names from Excel To Civil 3d?
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,297
    I have moved your question to the Civil 3D section: http://www.cadtutor.net/forum/forumd...vil-3D-amp-LDD
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    As far as I know, the only type of data you can import from Excel is points. Even if you could get pipe names from another file, I'm not sure how you'd know which name went with which pipe. Unless you gave the two ends of the pipe, but then you'd have to identify the entities at the ends.
    You could probably write a VBA script to assign pipe names, but the same dilemma happens. Which name goes with which pipe? Unless your project involves several hundred pipes, or you're a VBA whiz, it may take less time to enter the names manually.
    breaking AutoCAD on a regular basis since 1991
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,411
    Ahmed Elsaabbagh Have a look at Pipesample.dvb may have the answers its buried deeply in c:\program files\Autodesk\civ 3d ....... You may be able using the VBA code as a guide to write a Lisp version also.
    Cyberangel getting into the civ3d database can be quite difficult but contrary to your "only import points" that is if you are using "IMPORT" if you go via programming you should be be able to carry out so many procedures via reading excel info, it is about knowing what data you can get at easily using lisp or .net
    Older versions like 2012 had a lot more example code for doing things in VLISP etc under the CIV3DAPI, make surface models, pipenetwork, to mention a couple.
    One of the horrors with CIV3d is a lack of throw the data out and bring it back in all filled in. Dont mention styles and the 101 answers required. We have one piece of software and it exports to excel and brings back, it is much quicker to fill in that way than doing on screen in the original software and check for input errors as you go.
  5. #5
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,202
    Quote Originally Posted by BIGAL View Post
    I stand corrected. At my current job I don't have C3D. No way to check my answers except by Web search. For the obscure stuff I have to rely on my memory, which is not what it used to be.
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,411
    I do admit we dont use the PIPES inside civ3d so I am not sure about the original question as what the poster was really after in data input time saving, but answered the question as a more it can possibly be done.
  7. #7
    Junior Member
    Civil
    AutoCAD 2016
    May 2017
    12
    I really think everyone how tray to help me, what I need exactly is showing serial labels on the pipe, the DWG is already finished with random names... now we can export all network data with lisp COT and modified it, can we import it again to CIVIL 3D ? This only proposel to save time..
  8. #8
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,411
    I dont use the drainage software so post a small dwg so some of us can interrograte it.
  1. Using LISP to Import From Excel
    By Bill Tillman in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2015, 12:40 pm
  2. Import excel spreadsheet?
    By Evelynn in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Jan 2014, 03:01 am
  3. Import polygons from excel
    By omandgulf in forum .NET, ObjectARX & VBA
    Last Post: 22nd Apr 2013, 04:35 am
  4. Import Excel to DWGPROPS
    By cmangi86 in forum AutoCAD General
    Last Post: 4th Jan 2013, 04:54 pm
  5. import attribute to excel
    By rovinemarvic in forum AutoCAD General
    Last Post: 27th Jun 2010, 01:23 pm
Tags for this Thread
