Results 1 to 3 of 3
Thread: XREF pallet
    Forum Newbie
    Electrical
    AutoCAD LT 2017
    May 2017
    4
    Default XREF pallet
    Hi,
    I am new to CAD LT, I was trying to upload a pdf drawing file into the model, but when i type XREF in the command box, nothing shows. No pallets pop up.
    Is there a quick fix to this?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    For a PDF the command would be "pdfattatch" an Xref is for attaching other dwg files and the command is "_xattatch", having said that "xref" should open the xref manager.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    You can attach a variety of file formats from the XREF manager. The OP is doing it correctly.
    There are a couple of reasons for your pallet not showing up.
    It could be FILEDIA or maybe CMDDIA. Not sure which applies to the XREF manager.
    If you recently switched changed monitors, it might be off screen.
    If this is the case, there is a way to bring it back but I'm not sure how.
    Drafting is a breeze.
  1. Tool Pallet Update
    By Tahano54 in forum CAD Management
    Last Post: 5th Aug 2015, 02:00 am
  2. Missing tool pallet groups
    By hertz hound in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Sep 2014, 03:15 pm
  3. Replies: 0
    Last Post: 18th Oct 2013, 12:49 pm
  4. Tool Pallet
    By Jadgpanther in forum AutoCAD General
    Last Post: 19th Oct 2011, 04:05 pm
  5. Adding new block to pallet
    By richard3009 in forum AutoCAD General
    Last Post: 25th Mar 2010, 05:44 pm
