Window crashes reminder
ROBP
Familiar with new windows 10 crashes, please verify that your auto save was not altered .
A simple check will often prevent costly rework.
Been there so many times when windows freaks out the save option is changed.
Just a reminder to back check will often save user a lot of aggravation.
Enjoy
Best,
Robert
I watched a Lynne Allen Utube the other day, from Cadalyst and it was about improving auto save times, you can change also the % save value mine was set to 0 now I run 75%. I will see how much difference it makes.
Autosave timer restarts every time you manually Save the drawing, which you should do often.
I don't use AutoCAD on Windows 10, but I cannot recall my Windows 10 ever crashing, either.
