Results 1 to 2 of 2
Thread: Mleader break
    Full Member
    AutoCAD 2007
    Nov 2012
    45
    Default Mleader break
    Hi, hopefully a quick one.
    I am using Annotative Mleaders which cross Dim Lines and other Objects. I've tried to to use DIMBREAK to create a break where they cross but nothing happens.
    I've set the Break Size (assuming that's the property) in MLEADERSTYLE to the same as text size height i.e. 1.5mm
    AutoCAD LT 2017
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,216
    My guess would be that the current annotation scale is so much different than the mleader's scale that there isn't room in the leader for a break. It could be some other type of scale mismatch. As always, more info or a sample would help.
    Edit: could be the size of the break itself. You have to set it in the dim style.
    breaking AutoCAD on a regular basis since 1991
  1. Set MLeader to Existing MLeader Style via LISP
    By parkerdepriest in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2017, 09:13 am
  2. Select MLeader by Mleader style
    By pmayer in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2017, 06:56 pm
  3. Combining two LISP Routines - Leader to Mleader and Mleader Rotate
    By Cylis0509 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2016, 09:12 pm
  4. custom break or break settings
    By b.muqlueen in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Apr 2008, 05:46 pm
  5. custom break or break settings
    Last Post: 2nd Apr 2008, 01:19 pm
