Results 1 to 4 of 4
    Junior Member
    AutoCAD 2016
    Aug 2016
    20
    Default Code Lisp entget Hatch
    Hello everbody. Thank all for read my thread
    I want to determine the blue dot coordinates but fail. i hope everybody help me code lisp
    My code
    Code:
    ;;------------------------------=={  2017  }==-------------------------------;;
    (prompt "\n=={Created by PHÒNG TKCD - CIENCO625******************************}==")
    (prompt "\n=={Thanhdattdk@gmail.com******************************}==")
    (defun c:mm ()
    (princ "\nCh\U+1ECDn c\U+00E1c Hatch c\U+1EA7n t\U+1EA1o l\U+1EA1i Boundary : ")
    (command "-style" "DIENTICH" "arialbd_0.ttf" "0" "0.9" "0" "n" "n")
    (setq tnct (ssget (list (cons 0 "HATCH"))))
    (setq i 0)
    (setq lmt (sslength tnct))
    (while (< i lmt)
     		(setq e (ssname tnct i))
     		(setq laynd (entget e))
     		(setq td (cdr (assoc 10 laynd)))
    		;tao tap rong de tinh dien tinh cho Hatch tao nhieu PL
    		(setq S 0)
    		(setq Q (entlast) AA (ssadd))
    		(command "-hatchedit" e "B" "P" "")
    		(while
    		(setq Q (entnext Q))
    		(setq AA (ssadd Q AA))
    ;tinh dien tich cac phan tu cua group vua tao
    (setq j 0)
    (setq dat (sslength AA))
    (while (< j dat)
    (setq doituong (ssname AA j))
    (command "area" "o" doituong)
    (setq Si (getvar "area"))
    (setq S (+ S Si))
    (setq j (+ j 1))
    (princ S)
    (princ td)
    (command ".ERASE" AA "")
    ;viet text len vi tri hatch
    (command "text" "ml" td "2.5" "0" S "")
    (setq i (+ i 1))
    );END WHILE
    (princ))
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,592
    A quicker way maybe is use BPOLY it makes a pline of your hatch boundary, you can then get simply the co-ordinates of the new pline and theer are some centroid routines out there as well.
    Super Member
    not applicable
    Jun 2016
    673
    Since you are using the point to position text, why not calculate the center of the boundingbox instead of the centroid?
    BricsCAD 18
    Junior Member
    AutoCAD 2016
    Aug 2016
    20
    Default Thank you very much
    thank you very much.
    (setq Rec (acet-ent-geomextents e)
    pt1 (nth 0 Rec);lay dinh
    pt2 (nth 1 Rec);lay dinh
    mid (acet-geom-midpoint pt1 pt2)
    );setq
  1. Replies: 14
    Last Post: 21st Jan 2015, 06:23 am
  2. Hatch pattern error, making a "Hatch Code" .pat
    By SDSinc in forum AutoCAD General
    Last Post: 18th Jan 2011, 03:25 pm
  3. Help with Sample code to Entmake a Hatch
    By TuFoFi in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Dec 2009, 03:45 am
  4. entget problems!!!!
    By acatalin2003 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Oct 2005, 07:05 pm
  5. Problem with entget
    By carmenaz in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th May 2005, 09:39 pm
Tags for this Thread
