ASH_CAD Posted June 3, 2017 Share Posted June 3, 2017 How do I hide the line around a MVIEW when I save the Layout to a drawing? I need to be able save the drawing into a 2007 dwg in order to insert it into a Visio drawing but only want the model space not the frame around the viewport in Paper space. I am not plotting the drawing as otherwise I could just not plot the MVIEW layer. Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 3, 2017 Share Posted June 3, 2017 You haven't mentioned which options you have already tried if I understand the question correctly, you could try putting the viewport onto its own layer, then freezing that layer, and I then used the exportlayout command to create a new drawing, which works here. Quote Link to comment Share on other sites More sharing options...
Organic Posted June 3, 2017 Share Posted June 3, 2017 How are you saving the layout to a drawing? Quote Link to comment Share on other sites More sharing options...
