Results 1 to 10 of 10
    Junior Member
    AutoCAD 2015
    Nov 2016
    11
    Default LISP | IF Conditions | Copy to Existing Layer
    Goal: LISP that copies selected objects to existing layer, using layer name shortcuts.
    Example:
    1. Select objects
    2. "CX" (Lisp command) asks for layer to copy into
    3. "1CC" (Shortcut) Copies to actual layer name 1_COLS-CONT
    OR "2CC" copies to actual layer name 2_COLS-CONT, etc.
    I have the following LISP to start, and I just need to add all of the conditions for accepting a layer name shortcut and changing the layer to the corresponding one. I have a large number of layers, and so one lisp command for each seems too much.
    I understand that I would need multiple if conditions, but I need help with the actual code (fairly new to lisp).
    Thank you for your time!
    Code:
    ;FILENAME cx.LSP
    ;THIS LISP ROUTINE copies selected objects in place then prompts
    ;the user to change the layer of previus objects selected.
    ;BY Ryan 3/5/02
    (defun c:cx()
    (setq ss1 (ssget))
    (setq laycx (getstring "Destination layer for copy: "))
    (command "_copy" "P" "" "@" "@")
    (command "_chprop" "P" "" "la" laycx "")
    Senior Member
    guitarguy1685's Computer Details
    Window 10
    Dell Precision Tower 5810
    Dell
    Intel Xeon ES-1620 v3 @ 3.5GHz
    16GB
    Nvidia Quadro K4200
    Dual Dell U2412m
    See details...
    guitarguy1685's Discipline Details
    CAD Manager
    See details below.
    Building envelops & AES
    AutoCAD 2017
    Oct 2009
    302
    Here is my attempt. I didn't add any error handler, undo points, or control echo. I also made some changes in the command line.
    *edit* I also did not include any Layer Check/Create function.
    Code:
    (defun c:cx( / ss1 laycx Layer )
      (setq ss1 (ssget))
      (setq laycx (strcase (getstring "\nDestination layer for copy: ")))
      (cond					;;add as many conditions as you like.
        ((= laycx "1CC")
         (setq Layer "1_COLS-CONT"))
        ((= laycx "2CC")
         (setq Layer "2_COLS-CONT"))
      (command "_copy" ss1 "" "@" "@")
      (command "_chprop" "P" "" "la" Layer "")
    Last edited by guitarguy1685; 6th Jun 2017 at 04:52 pm. Reason: additional information.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,595
    I would suggest the following:
    Code:
    (defun c:cx ( / abr idx lay sel )
        (setq abr
                ("1CC" . "1_COLS-CONT")
                ("2CC" . "2_COLS-CONT")
        (if (setq sel (ssget "_:L"))
                (initget (LM:lst->str (mapcar 'car abr) " "))
                (setq lay
                    (cond
                        (   (cdr (assoc (getkword (strcat "\nLayer shortcut [" (LM:lst->str (mapcar 'car abr) "/") "] <" (caar abr) ">: ")) abr)))
                        (   (cdar abr))
                (if (not (tblsearch "layer" lay))
                    (entmake
                        (list
                           '(000 . "LAYER")
                           '(100 . "AcDbSymbolTableRecord")
                           '(100 . "AcDbLayerTableRecord")
                           '(070 . 0)
                            (cons 2 lay)
                (repeat (setq idx (sslength sel))
                    (vla-put-layer (vla-copy (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))) lay)
    ;; List to String  -  Lee Mac
    ;; Concatenates each string in a supplied list, separated by a given delimiter
    ;; lst - [lst] List of strings to concatenate
    ;; del - [str] Delimiter string to separate each item
    (defun LM:lst->str ( lst del )
        (if (cdr lst)
            (strcat (car lst) del (LM:lst->str (cdr lst) del))
            (car lst)
    (vl-load-com) (princ)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Junior Member
    AutoCAD 2015
    Nov 2016
    11
    Thanks for the reply guitarguy!
    Your edit works well, except that if I enter an unavailable shortcut it copies the objects to the 0 layer. I know you did mention there is no 'error handler', but it would be really useful to avoid unwanted duplicates.
  5. #5
    Junior Member
    AutoCAD 2015
    Nov 2016
    11
    Thanks for the reply Lee Mac!
    The lisp really meets my needs, but I do have another request. I find the dynamic list feature really cool, except there will be at least 200 shortcuts/layers and so the list would be too long. Could you please tell me how to suppress the display of the list? Everything else I really like, especially the 'Invalid option'.
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,711
    You could make a CSV text file with two items "shortcut,new layer name" and just read the file it could have as many lines as you like, Lee has a read csv so can get at the two items then just (if (= shortcut fileshortcut)(setq layname newlay)) post if you need an example.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,711
    Just thinking a bit more I was involved in a commercial product and we got round the layer problem by providing a user interface if you drew a particular object like say a wall the software knew what layers to put everthing on, so no layer problems. It had a text file in the back end for layer names.
    It sounds like your random drafting then fixing up, rather than trying to control as you create. Maybe use the same idea. I have posted some reactor code which could do what you want type 1CC 2CC etc and it knows you want to draw on layer 1_COLS-CONT.
    http://www.cadtutor.net/forum/showth...-radius./page3
  8. #8
    Junior Member
    AutoCAD 2015
    Nov 2016
    11
    Thanks for the reply bigal!
    At this point, I am most comfortable implementing Lee Mac's solution. Except for that dynamic list I cannot figure out how to suppress/remove, it meets our current needs.
    However, I will look into your suggestions for future lisp developments
  9. #9
    Senior Member
    Window 10
    Dell
    16GB
    Nvidia Quadro K4200
    Dual Dell U2412m
    See details...
    CAD Manager
    See details below.
    AutoCAD 2017
    Oct 2009
    302
    Take this line
    Code:
    Change it to this.
    Code:
    (   (cdr (assoc (getkword (strcat "\nLayer shortcut: <"   (caar abr) ">: ")) abr)))
    That should suppress all the layer names.
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,711
    Have a look at this post it can be changed to work with layers as you want so no need for multiple shortcuts looking at other code I would use "L" then your shortcut L1CC" You can though use 1 if you want or 2 or 3 etc.
    http://www.cadtutor.net/forum/showth...nother-drawing
  1. .LIN file missing and i need to copy/edit and existing linetype!
    By R1CK3R5 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 26th Mar 2015, 12:17 pm
  2. Replies: 9
    Last Post: 15th Dec 2011, 08:26 pm
  3. copy layer and sort, sometime duble copy
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Feb 2011, 02:38 pm
  4. Tough Questions - Copy Xref Layer Lisp
    By johnshar123xx in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Dec 2009, 04:04 pm
  5. Conditions with LISP
    By homer in forum AutoCAD Beginners' Area
    Last Post: 10th May 2007, 03:21 pm
Tags for this Thread
