Results 1 to 8 of 8
Thread: Mesh to solid
    Junior Member
    Construction
    AutoCAD 2015
    Jun 2017
    10
    Default Mesh to solid
    Helo, I have many mesh and need convert to solid 3D, the adjunt is a example.
    Any lisp, visual lisp for this.
    thank you.
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    657
    I wonder what you exactly did to get this result?
    I think these meshes really look awful, my guess this is a exotic import coming from.. to.. via.. what?
    my advice, (like it or not)
    Start the modelling proces over in AutoCAD to get something decent.
    O,.. and welcome here..
    No hard feeling, ;-) .. just my reaction ..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Junior Member
    Construction
    AutoCAD 2015
    Jun 2017
    10
    It is just the problem.
    I use same programs, but donĀ“t achieve a good result.
    m2s
    automesher
    polyhedral mesh to solid
    mesh to solid (sycode)
    AutoCAD 2017
    Jul 2015
    657
    What stops you to just model it as solid in the first place?
  5. #5
    Junior Member
    Construction
    AutoCAD 2015
    Jun 2017
    10
    The time, the measures are not availables, the the file is only a example.
  6. #6
    Junior Member
    Construction
    AutoCAD 2015
    Jun 2017
    10
    The model avaliable is only in Navisworks, it was exported using fbximport to autocad.
  7. #7
    AutoCAD 2017
    Jul 2015
    657
    Horrible.. I think the best thing you can do is to find the person that can provide you the native designfile.
  8. #8
    Junior Member
    Construction
    AutoCAD 2015
    Jun 2017
    10
    I already tried and it was not possible.
  1. 3D solid to 3D mesh
    By nkme2007 in forum Civil 3D & LDD
    Last Post: 20th Jan 2013, 02:37 pm
  2. solid to mesh
    By vaggos in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Nov 2007, 05:52 pm
  3. mesh to solid
    By Raider in forum AutoCAD General
    Last Post: 1st Aug 2006, 03:57 am
  4. m2s Mesh-to-Solid
    By CADTutor in forum Application Archive
    Last Post: 7th May 2004, 06:26 pm
  5. 3d mesh To Solid?
    By John Dory in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 10:51 am
Tags for this Thread
