Results 1 to 9 of 9
    Forum Newbie
    Surveying
    Civil 3D 2011
    Nov 2014
    Las Vegas
    9
    Default Converting from C3D 2017 to C3D 2014
    Is there a way to convert a 2017 drawing to a usable 2014 drawing? If I receive drawings from a PE whose office is using 2017, to prepare for staking, I can't use them unless I copy the linework to a blank 2014 drawing. Then I lose the surface information.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Download the newest version of DWG TrueView from the AutoDesk site. It is FREE. It can down convert to any older DWG file version all the way back to hammer and chisel days. (reletively speaking).
    Some people have had issues with TrueView taking over as the default program for opening a DWG file after it has been used. Possibly, the next time you double click a DWG file in Windows file explorer, TrueView will open it instead of AutoCad. If this happens, go to AutoCad and open any dwg file. Then close it. The default will then be reset to AutoCad. You can also correct it by going to Control Panel and resetting the default there to AutoCad.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Newbie
    Surveying
    Civil 3D 2011
    Nov 2014
    Las Vegas
    9
    I'll give it a try. Thanks!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I'm left wondering if you will still encounter incompatibility issues using DWG Trueview.
  5. #5
    Super Moderator
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,478
    Quote Originally Posted by Sasparilla View Post
    No, there is no way to do that, unless the only Civil objects are LandXML supported (cogo points, surface, alignment, etc)
    In that case, you can transfer those objects via LandXML and transfer the base cad entities (lines, text, polylines, etc) via the drawing file itself.
    This is all clearly documented
    Trueview is not going to help you any, and even if it would, it's not needed because there is no difference in DWG versions here.
    2013-2017 DWG versions are the SAME.
    R.K. McSwain
    CAD Panacea | twitter
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by rkmcswain View Post
    My mistake. I thought 2017 was the format change year. Must be 2018 then. I didn't even notice I was in the C3D forum.
  7. #7
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    439
    We had the same problem with our survey guys. They run Carlson and we run Civ 3D 2018. There Carlson is a later edition and when I sent the file to our surveyor, he was unable to even open the file. Had to do a EXPORTTOAUTOCAD2013 for them to be able to utilize and save the file. Would NOT let him save a file if i did a SAVEAS 2013 edition. If I am not mistaken, the Civil objects are exactly what the issue was.
  8. #8
    Super Moderator
    Windows 7 Pro x64
    HP ZBook 17
    16GB
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,478
    Quote Originally Posted by MillerMG View Post
    Carlson is not a CAD version. Carlson runs on top of AutoCAD or Civil 3D or other CAD engines.
    2018 is a new DWG version, incompatible with any earlier version. The presence or absence of Civil objects makes no difference in this case.
    R.K. McSwain
  9. #9
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    439
    Good to know. Thank you as always for being insightful rkmcswain
  1. cad 2017
    By hila in forum AutoCAD Beginners' Area
    Last Post: 3rd Jun 2016, 07:07 pm
  2. What's New in AutoCAD 2017 – AutoCAD 2017 Preview Guide
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 26th Mar 2016, 12:14 am
  3. Replies: 5
    Last Post: 4th Mar 2014, 05:07 pm
  4. AutoCAD 2014 & Revit 2014 Free Book Titles Released
    Last Post: 31st May 2013, 08:20 pm
  5. AutoCAD 2014 & AutoCAD LT 2014 Preview Guides
    Last Post: 28th Mar 2013, 07:10 pm
