Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Super Member
    not applicable
    Jun 2016
    701
    You can quite easily perform this task manually with two move operations.
    BricsCAD 18
  2. #12
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,490
    I'd just swap the two selection sets by their centroids.
  3. #13
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,106
    [QUOTE=Tharwat;685933]Try this:
    [CODE]
    (defun c:Test ( / one two no1 ob1 ls1 no2 ob2 ls2 sr1 sr2 nos a b en1 en2)
    ;; Tharwat
    Beautiful!
  4. #14
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,267
    Quote Originally Posted by rlx View Post
    Beautiful!
    Thank you.
  5. #15
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    Quote Originally Posted by Tharwat View Post
    Thank you.
    I did make something simular for my VT text editor but its much bigger and not nearly as elegant as yours. But it can do multiple rows (or columns) and also attributes.
    Code:
    ; based on VT.lsp by Rlx
    (defun c:SwapTextRows ( / p1 p2 el1 el2 tl1 tl2)
      (if (and (setq el1 (sfs (setq p1 (getpoint "\nSelect 1st corner source row(s) : "))
         (setq p2 (getcorner p1 "\nOther corner : "))))
        (setq el2 (sfs (setq p1 (getpoint "\nSelect 1st corner target row(s) : "))
         (setq p2 (getcorner p1 "\nOther corner : ")))))
          (setq el1 (SortElist el1) tl1 (mapcar '(lambda (x) (cdr (assoc 1 (entget x)))) el1)
         el2 (SortElist el2) tl2 (mapcar '(lambda (x) (cdr (assoc 1 (entget x)))) el2))
          (us el1 tl2)
          (us el2 tl1)
    ;remove duplicates
    (defun rdup ( i / o ) (vl-remove-if '(lambda (x) (cond ((vl-position x o) t) ((setq o (cons x o)) nil))) i))
    ;get insertion point
    (defun getip ( e / ent)
      (setq ent (vlax-ename->vla-object e))
      (if (= (vla-get-alignment ent) 0)
        (reverse (cdr (reverse (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint ent))))))
        (reverse (cdr (reverse (vlax-safearray->list (vlax-variant-value (vla-get-TextAlignmentPoint ent))))))))
    ;el = elist , xl = x , yl = y , ml = matrix , sl = sorted elist
    (defun SortElist ( %elist / el xl yl ml sl)
      (if %elist
          (setq el (mapcar '(lambda (x) (list (getip x) x)) %elist) ; %elist -> el ( ((ip)e1) ((ip)e2) .. )
         xl (vl-sort (rdup (mapcar 'caar el)) '<) yl (vl-sort (rdup (mapcar 'cadar el)) '>))
          (foreach y yl (foreach x xl (setq ml (append ml (list (list x y))))));sort by row
          (setq sl (vl-remove 'nil (mapcar '(lambda (x) (if (assoc x el)(cadr (assoc x el)))) ml))))))
    ; update string
    (defun us (%el %sl)
      (mapcar '(lambda (e s / en)(setq en (entget e))(entmod (subst (cons 1 s) (assoc 1 en) en))) %el %sl))
    ; (point) inside window
    (defun inside_w (ent p1 p2 / ip )
      (setq ip (getip ent))
      (if (and (>= (car ip)  (min (car p1)(car p2)))   (<= (car ip)  (max (car p1)(car p2)))
        (>= (cadr ip) (min (cadr p1)(cadr p2))) (<= (cadr ip) (max (cadr p1)(cadr p2)))) t nil))
    ;scan for string
    (defun sfs ( %p1 %p2 / i ss el e et)
     (if (setq i 0 ss (ssget "c" %p1 %p2))
       (while (setq e (ssname ss i))
        (setq et (cdr (assoc 0 (entget e))) i (1+ i))
        (cond ((member et '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))(setq el (cons e el)))
       ((= et "INSERT") (mapcar '(lambda (x) (if (inside_w x %p1 %p2)(setq el (cons x el))))(get-ents e)))))) el)
    ; get (block) entities
    (defun get-ents ( b / obj e lst)
      ;attrib
      (setq obj (vlax-ename->vla-object b))
      (if (eq :vlax-true (vla-get-HasAttributes obj)) (setq lst (mapcar 'vlax-vla-object->ename (vlax-invoke obj 'GetAttributes))))
      ;text , disable if only attributes are needed
      (setq e (tblobjname "block" (vla-Get-EffectiveName obj)))
      (while (setq e (entnext e)) (if (member (cdr (assoc 0 (entget e))) (list "TEXT" "ATTDEF")) (setq lst (cons e lst)))) lst)
    I try to be as elegant as a 'dragon' can be ... but sometimes ... when it works , it works :-)
    gr. Rlx
  6. #16
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,490
    Tharwat, you inspired me to play with this - grread version:
    Code:
    ; Grrr - Exploded Table Shift Rows
    ; Credits to: Lee Mac, Tharwat
    ; 1. Select text/mtext that are representing cells from a exploded table
    ; 2. Use grread to shift their values
    (defun C:test ( / SS->SortedMatrixL ShiftL L vL grr Stop )
      ; Map to the nth level items - Lee Mac :
      (defun mapncar ( n f l ) (if (< 0 n) (mapcar '(lambda ( x ) (mapncar (1- n) f x)) l) (mapcar f l) ) )
      ; (mysort (lambda (a b) (apply '< (mapcar 'car (list a b)))) pL)
      (defun mysort ( f L ) (mapcar (function (lambda (x) (nth x L))) (vl-sort-i L (function f))) )
      ;; Unique with Fuzz  -  Lee Mac
      ;; Returns a list with all elements considered duplicate to a given tolerance removed.
      (defun LM:UniqueFuzz ( l f / x r )
        (while l (setq x (car l) l (vl-remove-if (function (lambda ( y ) (equal x y f))) (cdr l)) r (cons x r) ) ) (reverse r)
      (setq SS->SortedMatrixL
        (lambda ( fuzz / SS i o L tmpL rtn )
          (cond
            ( (and (princ "\nSelect Text-Cells from Exploded Table to Shift: ") (setq SS (ssget "_:L-I" '((0 . "*TEXT")))))
              (repeat (setq i (sslength SS))
                (setq o (vlax-ename->vla-object (ssname SS (setq i (1- i)))))
                (setq L (cons (list (vlax-get o 'InsertionPoint) o) L))
              ); repeat
              (foreach x (LM:UniqueFuzz (mapcar 'caar L) fuzz)
                (and
                  (setq tmpL (vl-remove-if-not (function (lambda (q) (equal x (caar q) fuzz))) L))
                  (setq tmpL (mysort (lambda (a b) (apply '< (mapcar 'cadr (mapcar 'car (list a b))))) tmpL))
                  (setq rtn (cons tmpL rtn))
                ); and
              ); foreach
              (and rtn
                (setq rtn (vl-sort rtn (function (lambda (a b) (> (caaar a) (caaar b))))))
                (setq rtn (mapncar 1 '(lambda (x) (cadr x)) rtn))
              ); and
              rtn
            ); SS
          ); cond
        ); lambda
      ); setq SS->SortedMatrixL
      (setq ShiftL (lambda ( fl L ) (if (vl-consp L) (if fl (append (cdr L) (list (car L))) (append (list (last L)) (reverse (cdr (reverse L))))))))
      (cond
        ( (not (setq L (SS->SortedMatrixL 1e-1))) (princ "\n Nothing Selected or Invalid Selection") ) ; '((o1 o2 o3) (o4 o5 o6) (o7 o8 o9))
        ( (not (and (vl-every 'vl-consp L) (apply '= (mapcar 'length L)))) (princ "\n Invalid Selection: Select equal amount of items per row.") )
        ( (princ "\nPress [W] or [S] to shift the Rows | [A] or [D] to shift the Columns <exit>: ")
          (setq vL (mapcar 'vla-get-TextString (apply 'append L))) ; values
          (while (not Stop) (setq grr (grread T))
            (and (or (equal grr '(2 13)) (member (car grr) '(3 25))) (setq Stop T)) ; Exit keys = ENTER or LMB/RMB
            (cond
              ( (and (= (car grr) 2) ) ; KBD
                (and
                  (cond
                    ( (member (cadr grr) '(97 65)) (setq L (ShiftL T L)) )
                    ( (member (cadr grr) '(100 68)) (setq L (ShiftL nil L)) )
                    ( (member (cadr grr) '(119 87)) (setq L (mapcar (function (lambda (x) (ShiftL T x))) L)) )
                    ( (member (cadr grr) '(115 83)) (setq L (mapcar (function (lambda (x) (ShiftL nil x))) L)) )
                  ); cond
                  (mapcar (function vla-put-TextString) (apply 'append L) vL)
                ); and
              ); KBD
            ); cond
          ); while
      ); cond
    ); defun C:test
    Although I think that the simpliest way to "switch" both selections would be the way I mentioned in my previous post.
    Not sure if posting the code of my previous demo will be a good idea, since I appreciate your programming work - and I don't feel like spreading freeware programs (although that was easy to assemble from a couple of subfunctions).
  7. #17
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,267
    Quote Originally Posted by Grrr View Post
    Cool.
    Nicely done.
  8. #18
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    [QUOTE=Grrr;686042] Tharwat, you inspired me to play with this
    Not sure if this is what requester wanted but brilliant nevertheless
  9. #19
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,490
    Thank you guys for the positive feedback!
    Hopefully you could benefit from that code.
  10. #20
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,106
    I'm not sure if the smoke comming out of my brain when looking at your code is a benefit for me right now , but in time I hope to understand your code
  1. Lisp for switching multiple layers...?
    By Rsblades in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Sep 2014, 05:43 am
  2. Switching layout tabs with lisp
    By Grigs in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2013, 11:33 pm
  3. Lisp for switching layouts
    By OMEGA-ThundeR in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2012, 05:37 pm
  4. Lisp For Autocad Table
    By rochel1280 in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Mar 2010, 07:08 am
  5. lisp: no items in selection
    By markschu in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jul 2009, 01:11 pm
Tags for this Thread
