Ski_Me Posted June 12, 2017 Share Posted June 12, 2017 I created a custom line type to represent my wire but when I use it doesn't show the wire going all the way to my devices. As you can see the line doesn't extend to where the line starts or ends. I cant figure this out. linetype.dwg Quote Link to comment Share on other sites More sharing options...
eldon Posted June 13, 2017 Share Posted June 13, 2017 You could have provided more information. Your linetype appears to be a complex one, which contains a shape. However you have not posted that shape file, nor have you posted the linetype definition file. So I will guess. It appears that your linetype starts and finishes with a dot. With A-type alignment, AutoCAD varies the length of the first and last dash length to suit. However a dot has no length, so I suspect that AutoCAD is varying the length of the space between the dot and the first dash. AutoCAD is drawing your linetype correctly. Quote Link to comment Share on other sites More sharing options...
