Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Full Member
    wezzo18's Computer Details
    Windows 10
    Architectural
    AutoCAD 2015
    Mar 2017
    46
    no i wasnt... i need there to be no space between the two
  2. #12
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by wezzo18 View Post
    You CAN do it, just focus, and nobody better to show you the ropes than ReMark.
    Please don't squander the opportunity by resisting.
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    I gave you two different methods for achieving this particular result (no space = a solid). If one did not work then try the other. There really is no good reason why either method would not work. I know because I tested both.
    Note that the PRESSPULL command will work on any combination of lines, polylines, arcs and splines. Upon taking a closer look at your 2D profile I notice it is comprised of three polylines, two arcs and three lines for a total of eight objects.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Look at the image below. The three magenta colored objects are polylines. Anything that is white is either a line or an arc.
    Use the PEDIT command with the JOIN option to connect all eight objects into one continuous polyline then extrude it. The result should yield a solid.
    How to use the PEDIT command...
    Command: PEDIT
    Select polyline or [Multiple]:
    Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype gen/Reverse/Undo]: J
    Select objects: 1 found
    Select objects: 1 found, 2 total
    Select objects: 1 found, 3 total
    Select objects: 1 found, 4 total
    Select objects: 1 found, 5 total
    Select objects: 1 found, 6 total
    Select objects: 1 found, 7 total
    Select objects: 1 found, 8 total
    Select objects:
    8 segments added to polyline
    Question:
    Did you know your profile does not have a uniform width throughout? Was that intentional?
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    These are the varying widths of your profile. Why the variation?
  1. creating an egg shaped solid
    By johnfulwyler in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Jul 2015, 05:48 pm
  2. Creating a mesh to a solid in 3ds max
    By cameroon95 in forum 3D Modelling
    Last Post: 21st Oct 2011, 08:07 pm
  3. Creating a Solid
    By nicnicman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Oct 2008, 11:28 pm
  4. Need help with creating complex solid
    By McKew in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st May 2008, 11:06 am
  5. Creating 3D solid
    By careyc in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Mar 2005, 08:48 pm
